Air Condition Problems
TannerW
I wanted to post some symptoms of my air condition to see if anyone may know what the problem is. When the AC is on the highest fan setting it feels like it is blowing heat. A few months ago I did an AC recharge which seemed to help but when trying this time the digital gauge read 0 psi and would not increase. Is there anything I should check to see what may be going on?
Thanks!
Thanks!
they make a dye that you can inject into the system, theirs one that has the adaptor already on the can. drive around for a day or two. i picked up a UV light on amazon for $6. i eneded up putting a new unit in mine, bought the vaccum tool to get all the air out and recharged the line, has been fantastic every since.
Thanks!
If you are adding refrigerant and pressure is not increasing, you have a big leak. Adding dye is the right answer and then look for the leak...should be readily apparent. Make sure you check the evaporator drain hose on the firewall.
after i found the leak, i replaced the condensor which came with a dryer, vaccummed the system and turned it on. my compressor would go no higher than 80 and than drop, i tried refilling refrigerant and no luck, still dropped pressure. bought a new compressor, redid the work, vaccum, refilled to spec, and bam has been great ever since.
