Air Recirculator
milbot
My air recirculator is stuck in the recycle mode. I cannot switch it to outside air. I have the automatic climate control. I searched and could not find an answer. Please help.
Is it stuck in the sense if you press it never de-activates? Did you check the manual? If yes, I do not know, but my reason for posting was to ask a similar question about the same thing.
Certain settings: AC, lower the temperature and the recycle kicks in, etc. Certain things just activates the recycle air button even if I do not want it to. Is there a way to set it so to NEVER turn it on, unless I specifically press the button?
by off chance are you running the temp setting at LO? if you do, the climate control will turn on/off the recirc button as needed. just set the temp at 65 instead.
on mine if i set it at LO the recirc button will lite up.
I figured out the problem, it was just as you suggested. Now my auto setting will not come on at all. This is most upsetting.
I do not know if this will help, but if you push the Auto button, and then change the fan speed or air direction, the auto mode will turn off.
From the sound of things, it seems like there is something wrong with the board that controls the Auto AC. At first, I thought maybe the light went out on the Auto button, but then I read further down that nothing happens.
