Airing down.......the compressor thread.
Coctailer
What are you guys using for an air compressor to air back up after leaving the trails and hitting the highway home?
12v Puma Compressor with a 1.5 gallon tank. 100% duty cycle
Superflow MV-50, a small compressor that's a stop-gap until I can get my onboard air system (probably the new ARB unit, 100% duty cycle, can run air tools on top of the locker I intend to get). The Superflow airs up my 35's from 15-35 in about 3 minutes each--not bad for a relatively tiny unit. Cost about $75.
I use a 40 lb bottle of compressed Nitrogen. I have an account at a local welding shop and I use up to 4 bottles a week at work so I figured since I get it real cheap I might as well put a regulator on it and use it to air up my tires. I have used one bottle to air up all four of my 35's,my buddy's 38'tsl's, my bro in laws 32's,2 air matress and even use air tools off of it. I have yet to run out of air at the end of a trip.
Granted my bottle isn't as PRETTY as a "Power Tank" but at $10 a refill and $100 regulator I'm happy. I looked at the price of power tank and DANG!! They ask over $500 for a setup. Also a bottle of Nitrogen is filled up to 3000psi and if I remember correctly CO2 is only 1500psi. Another cool deal is when it does run out I just swing by the LWS and swap it out.
That puma tank is pretty sweet though too. It definitely has some cool Bling factor.
Funny thing is....I have an ARB compressor STRICKLY to run my locker. I've heard stories of people wiping out there ARB's from water condensation from their tanks. I geuss if you drain your tanks religously then you'd be fine but I have to be honest... I Never do :)
I use this:
S6300758.jpg~original
I aired up my 4 35x12.5 tires plus my buddies 4 33x12.5 tires in all about 5-7 minutes. We went from 15 to 25 psi with no issues. Unless you need an air compressor to run an air locker, I would stay away from the compressors. They take way too long to air up tires. Just my .02.
I use this:
It all depends on the VOLUME the compressor flows--many boast about their pressure rating, but they often only flow about 1.5-3 cfm. Something like the newest ARB unit flows over 6 cfm, which will fill even large tires in no time (it can even run air tools, the true test of a compressor's flow).
