Just curious where did you put those round blocks? I never used mine, I was under the assumption that with our suspension set up they were not used.
I just installed the same bags on my 99 limited, they work great. I hooked up my boat that usually squats the rear end and with 20 or so psi in the bags it sat even and towed great. Install wasnt too bad, I mounted my fill valve under the rear bumper for easy fill up. I plan on putting a compressor in soon so I can adjust from inside the cab! Great product in my opinion.
Damn dude! Very very very nice write up!
Perfect for anyone who might want to install as well.
I'm glad you could figure it out especially with us having two different type of coils.
And I'm also happy that your wife approves of it as wellthat's always a plus
And about the Hawaiian dressing. To be honest, I don't even know what that is.
Hahaha but soda crackers are for any occasion.
Usually the best to put on your soup!
Or when your sick, that and Gatorade are easy to eat haha!
It's interesting to hear as well you guys don't have soda crackers?
Good to hear it works out well! Enjoy it!
Aloha!
Its hard to see but here mine with the lift
From top down
Stock cone cut down
10mm spacer
2.5in puck
air bags
the air lines go up and they are each filled separately.
I love this system. it works great for when im moving or towing. when they are full, the ride is stiffer but not unbearable at all.
From top down
Stock cone cut down
10mm spacer
2.5in puck
air bags
Should my bags have this much space between spring seats? I did the cone cutoff and did not use the 2.5 inch supplied puck. I do have OME 2890 springs.
Not sure why anyone would run 2 lines rather than T. If one bag leaks they stay the same or both loose all air, running seperate would really unballance the load. I broke 2 in the Landcruiser and warranty is great ($10).
