Airsoft BB's Balancing
SCRunner12
Has anyone used airsoft BB's to balance their tires. I know there is Dynabeads, but I'm not going to pay $80 for beads. Anyone used them on 32's or 33's?
I use steel BBs. Plastic air soft BBs are too light if you need allot of weight.
I use them in my Jeep which is not a daily driver. They are a good solution ONLY IF you have issues using a more conventional weight balance. My issue was I world rip off weights when I wheeled with my jeep. My jeep also has more aggressive tire that don't balance that well to start with. It takes close to a bound of weights to balance them, and even then I get vibes above about 60mph.
Using the BBS won't get nearly as good of a balance as you with external weights.
Sometimes in low speed turns, you'll get the bb's all fall, and you get a pretty horrendouns vibration for a few seconds till the spin out again.
I just didn't bother balancing the 37's :)
Crookedcat
