Alarm 5th Gen
jackolero
I finally realized that the Security light thingy on my SR5 is not actually an alarm system so now I'm trying to find the best alarm option for my 2013 SR5. Search doesn't yield much I guess 5th gen still fairly new considering earlier gen.
I'm looking at this viper 5904 with remote start feature. Anyone here have that alarm on their t4r? Can you program the viper key to roll all windows and moon roof like the OEM key fob? Or possibly roll them up/shut now using viper system? Any warranty issues might arise having other than the dealer do the install?
Could you guys post what kind/model of alarm system you have, who installed it, how much and what extra features you like best or find most useful. I'd appreciate any inputs on this.
Yes all that will work just fine granted you find a competent installer to put in the 5904 and hook up all the auxiliary features you want. I have a 5704 myself and installed it myself, so basically it was just the price of the alarm (~200-300 bucks or so, I forgot) and a lot of sweat, some blood shed and cursing along the way.
No warranty issues for the most part, unless they can prove that the alarm broke whatever you are trying to warranty. For example, if your water pump starts leaking, no you won't have any warranty issues; but if your transponder key electronics starts acting up, you might have issues since your alarm taps into this for the remote start feature.
Please, please, please find yourself a competent installer, since these 4runners are very high tech and have a lot of electronics on-board that you can easily screw up while installing an alarm.
Eddiebx: Sounds great! With your install you just bought the viper alarm module 5904 and were able to program all of the above functions I mentioned without an extra additional module like a bypass for remote start and none of the hidden extra key ? Were you also able to program the rear window to roll down and up with the viper remote as well? How about when locking the t4r with OEM key fob does it arm the alarm as well or do they function separately? Any other nifty functions that you can think with the 5904?
I agree with having a competent installer which I know would be a challenge finding. What questions do you recommend asking an installer to guage if they're worthy with tinkering with the mighty T4R?:hail: How much would do you think is a reasonable rate for an install?
I enabled all of the aux functions like rolling the windows/sunroof up and down with just the alarm module itself, but you need a bypass module for the remote start and OEM alarm integration. What I used was the XpressKit DB-ALL, but Audiovox also makes an FL-CAN, which is similar. There are also lots of no name brand ones but I've not a clue how good they are. These modules allow you to integrate a lot of the functions and sensors through the CANBUS, instead of manually tapping/splicing in wires; and it also allows you to bypass the transponder without losing a spare transponder key (you basically learn the key code into the module itself and it will send it back to the transponder ECU when you try to remote start).
I should be able to hook up the tailgate window roll up and down functions eventually, but I haven't had the time to go into the tail gate yet and tap some wires, so for now, it's a maybe. Though I've looked at the wiring diagrams and I think I should be able to make it work.
As far as prices to expect, I am honestly not sure since I always do my own electrical work on my vehicles...but questions you can ask them are how do they plan to do the transponder bypass, do they solder the connections, if not, do they crimp and what kind of crimps (a proper crimp is very hard to achieve, and requires very specialized tools and crimps). For the most part, the best connection method you will get from audio/security installers are solder joint, and there's nothing wrong with that so long as they are done properly and covered properly (heat shrink tubing where possible).
I would probably just ask around locally and hear the reviews from people whom actually have had work done by them, and then go check out their shops and take it from there. I don't mean to scare you, but I've read a horror story here on this forum about someone getting a viper remote start installed on a 5th generation and ended up having to replace the whole ECU I think.
If you see them show you these types of connections below, run far far away :)
image-310.php
Im running the 5904 in my truck right now, its a worth every penny, but like the other member said, get a competent and certified installer. Pay the money, it'll save you a headache in the long run. Most installers will warranty the install and wont backyard the wiring and sensors. If you get remote start, the key that needs to get put into the brain is a new type of key. I had to go to like 3 places before to make a second set just so they could put it in.
Well just found out that there is actually a factory alarm that is not enabled. Found out through techstream that you can enable this and it even have a break glass feature. Basic alarm that beeps the horn when door is opened. Can't understand why toyota would hide this feature. I hope dealers are not charging for factory alarm installs.
Wait, say what? This is on a standard SR5?
Yes standard sr5 with convenience package. enabled and tested exactly midnight and waking up baby and wife.:biggrin2:
Techstream custom settings are pretty straightforward though, it'll say not available or just give you no option to enable it when it's not available. can't they just use the phone mic though.? There's only one way to find out, but I'll wait until tomorrow to test it out.
i wonder if this is only on the '13 model year or if my '12 SR5 also has it. how did you figure out it was there? My dealer suggested i go to a third party shop that they used for installs. i haven't done it yet.
You might want to look into using Raychem splices for this type of wiring. They are a metal barrel crimp splice with a heat shrink sleeve that covers the barrel. If done correctly they are virtually immersion proof. I use them on aircraft all the time. You do need special crimpers; but I have a pair. Here's a link:
http://raychem.te.com/documents/webservice/fetch.ashx?fileid=8460&docId=927
They come in three sizes that I know of:
22ga red
20ga blue
16ga yellow
Just going over every single customizable options on techstream. It's under options setup and security. You probably have it too. I got the same reply when I ask them about alarms. It just shows how much dealers knows about the car they're selling. Any suggestions to test the broken glass sensor without actually breaking my glass.:brick:
I have a 2013 SR5 and found out that my alarm does work. I locked the door with the remote while still inside, when I got out about 10 minutes later using the handle to unlock the door the alarm went off. Surprised me to say the least. Good find on the programing with the Techstream I am going to check that out.
I fond that out on our Tundra. I locked it at Sam's Club but in wouldn't unlock with the remote (battery was dead). I unlocked with the key. When I opened the door the alarm went off. Starting the truck cancelled the alarm.
:thanks: I just enabled my alarm too! My dealer wanted $600+ for this option I believe.
You guys whom have "enabled" this feature, any of you actually test to see if there really is a glass sensor? It's pretty simple, you just take a key and tap on the window with it, obviously not hard enough to break it, lol.
Also, can you guys tell me if your alarm will go off when you pop the hood? Supposedly the SR5s might not have a hood switch, but I am not sure about that...I just read it somewhere.
I am guessing Tech Stream is a software you can buy that comes with a plug for the Rig?
Yep, except you get the plug off ebay usually, and it comes with uhhh "unlocked" techstream software, lol.
The actual TIS Techstream is a Toyota paid subscription service software, that Toyota tech usually subscribe to, but the price is very prohibitive for most hobbyists. That's why we buy the cable off ebay :)
Read here for all things about techstream: http://www.toyota-4runner.org/5th-gen-t4rs/121604-toyota-tis-techstream.html
Philthyphilthy
