Alarm upgrade TOYOTA 4RUNNER 03-05
taeeno
4RUNNER ALARM UP GRADE KIT RS3200 PLUS
By adding this kit to your 2003-2005 4RUNNER with keyless entry, you will have the remote armed and disarmed security system that is the FACTORY ORIGINAL EQUIPEMENT. It is NEW and has NOT BEEN USED. Below is a list of features copied off of Toyota accessories broacher #00107-00329 available from Toyota dealers.
SECURITY AND CONVENIENCE ALL AT THE TOUCH OF A BUTTON
Vehicle Specific Design: VIP system is custom built specifically for your Toyota vehicle
Point-of-Entry-Protection: Activates VIP's full alarm cycle if any door, trunk, or hatch is opened without the key
Full Alarm Cycle: For 60 seconds the lights flash, horn sounds, starter is disabled, and the Forced Lock feature will continue to re-lock the doors(on models with electric locks)
Starter Disable: Prevents the vehicle from being started after the alarm is triggered
Hot-Wire Protection: Sounds the alarm and disables the starter if an attemt is made to start the vehicle without the key
Rolling Code Technology: Helps protect your VIP system from code grabbers that can steal your security codes
Glass Breakage Sensor: "Listens" for noise and triggers a 20 second Warm Away Alarm if it senses that the window glass is tapped or broken. Full alarm is triggered on the second detection
LED Display: Warns intruders that your vehicle is protected by VIP security
CONVENIENCE
Remote Keyless Entry: Conveniently locks and un-locks doors
Remote Arm/Disarm: Activates/deactivate VIP system via remote control
Passive Disarming: Allows ignition key to disarm VIP security system after automatic arming
Tail and Marker Lights Flash: Confirms successful arming or disarming
PERSONAL SAFETY
Panic Alarm Button: Remotely activates alarm to sound horn and flash exterior light
Door Ajar Warning: Sounds if a door is ajar when remotely arming the system
THIS KIT SELLS FOR $360+ AT THE DEALERS
fb_1.jpg~original
$200.00 or best offer
