Alignment Fun
ndbuck09
As always, I did a ton of searching for this but I can't find a super-definitive answer and the threads about FJ lifts, etc. are super long and I'm at work.
I just put in '11 FJ Springs and Bilstein 5100's set at 2.5 on my front end of 06 Limited. Going to be doing rear superflex soon.
I have an appointment to get my alignment done in a couple hours and I wanted to have some info for the tech so that they don't get all worried that they can't get things set up properly.
What numbers should I recommend they try to hit???
At 2.5" everything but caster should be able to get into spec. Maybe even caster can get into spec, but it will be close.
Here are the OEM specs for an '05, which is the same for you.
http://i140.photobucket.com/albums/...ilovers/4runneralignmentspecs500.jpg~original
You should try and have the Caster set to the higher end of the range but you won't be able too since you're lifting. Just make sure they set it as high as possible and most importantly that both sides are as close to the same number or better yet equal.
Camber and Toe, have them set it to the "Preferred Settings".
DionicioLives
