Alignment help?
JamesDean91
Okay so I'm just about done wrapping up my front end rebuild and would like some ideas our help on how to set my alignment to limp by until Monday when the shop is open.. I bought the light racing uca and replaced my lower control arm bushings so my castor/camber is all screwed.. I know how to set toe in with the tape and figured i could do the same with the castor/camber but i have never felt with anything like this before.
You should have marked the camber caster cam bolts so you could put them back to the same spot as before the repair. Only thing you can really do is get it on an alignment rack and front wheel aligned.
You won't find a bigger proponent of a true computerized alignment on this forum. I sell the equipment for a living! But I did alignments without equipment for years too.
You can do a crude alignment with a bubble level and a block of wood. If you can get the level to sit against the lip of the rim, you can get an idea what your camber is? 0 degrees will work for a few days. And if you have a way to measure 10 degrees of steering turn you could set caster too!
:couch2:
goddesszilla
