All 3VZE owner's
4runner_kid
Senior Member
To those that have header's with the automatic, where did you mount your 2nd ATF cooler or did you by pass it? Picture's if you got any. Thank's.
ill have to get pictures. i pretty sure i swapped the two lines going to the cooler. than i know for sure i loosen the lines coming from the trans and turned them so i could mount the cooler just in front of the fuel tank up high
Picture' when you can please.
sorry i took so long. here it is
if anything they are too long. im sure once you under yours and compare it to mine. you will see if i did swap the two lines or not. i wanna say i did and it allow better routing of the hoses.
Ok, thank's. I might try and knock that out this weekend if the weather is good. I'll post my picture's to.
Well your setup with the e brake cable bracket is different then mine. So i'm going to have to do something else.
Rialm
