All-Aluminum EC433 radiator install
Atomic6
Since moving out to Denver from Chicago in October, my wife and I have taken every chance we get to drive west into the Rockies. While the drive is breathtaking (literally and figuratively), the elevation has been a bit of a problem for the 4Runner’s cooling system (285s and stock gearing doesn't help). In all honesty, a stock replacement and new cap would have solved the problem, but I wanted to fit a larger capacity radiator in for peace of mind.
After searching high and low for a radiator with the correct core size, inlet/outlet location, mounting style, and thickness I found a suitable upgrade…
The Champion All-Aluminum Radiator. P/N: EC433
The EC433 is a 2-row replacement for the 1968-79 Ford F-Series 2WD and 1978-79 Bronco 2WD. There is a larger (thicker) 3-row CC433 that would probably work as well, but the EC is more than enough for the 3.4L. It also has a trans cooler just like our OEM, but I didn't use it as I bypassed mine to an external cooler.
As of writing this the EC433 is $175.99 at JEGS, but I got it for $160.95 shipped with their “Lowest Price Guarantee”. This is not the the out-the-door price for this mod though. There are a few more things you’ll have to buy.
Some specs to compare on the EC433 vs a stock replacement:
Core size:
EC433: 19-1/4”(H) x 25-3/4” (W) x 1-3/4” (T)
Stock: 22-5/8” (H) x 25-1/8” (W) x 1” (T)
So yes, the frontal surface area is smaller on the EC433, but the fluid capacity is much larger...
Volumes (not really since the core isn't completely full of fluid):
EC433: ~867.5in^3 (not counting the larger tanks)
Stock: ~586.45in^3 (not counting the smaller tanks)
Here's how I installed it…
Parts:
1- Champion EC433
1- 2” to 1-3/8” reducer coupler hose
1- 1-3/4” to 1-3/8” reducer coupler hose
1- 1-3/8 tubing joiner
1- 1-3/8 tubing joiner with sensor bung
1- Temp gauge
1- Stock lower radiator hose (modified for upper fitment)
1- Dayco 81031 1-1/4 Flex hose (still looking for a better solution than this for the lower hose)
4- Clip-on nuts (I bought them at my local ACE with some 1/4-20 bolts for the fan shroud)
4- 1/4-20 bolts
4- M8 bolts and nuts
Foam tape
Hose clamps
The aluminum radiator mounts will need to be cut for it to fit between the frame rails.
The best way I found to mark the locations was to remove the steel mounts from the stock radiator and push them into the new radiator. This is only for marking the vertical locations since the width is incorrect. I didn’t re-use these mounts. Note in the picture below, the top shroud bolts will need an additional support bracket.
After laying the shroud on the new radiator to check the placement, I marked, drilled, and installed the clip-on nuts for the lower mounts. These clips/holes are 14-3/4" (H) x 27-1/8" (W).
I had some aluminum stock laying around, so I used that as a bracket for the top shroud bolts, but you could use the off-cuts from a future step. Pictures of these are below after I cut the mounts.
Once the shroud bolted up, I used the same process to align, mark, and drill the holes for the mounting bolts to the core support. These mounting holes are 10-7/8" (H) x 27-1/4" (W). The new holes are the ones closest to the core in the below picture.
Then I cut the excess material off the brackets.
The brackets also had to be cut flush at the bottom to fit between the frame rails.
I didn't like that the aluminum would be in contact with the steel core support (even though its painted), so I added some foam tape between the two. (Also shown are the upper shroud brackets)
You can see the radiator shroud will need to be cut up to accommodate the inlet and outlets. I ruined this shroud by experimenting with mounting locations, but I have another that I'll be installing shortly.
Now the radiator can be slid in place and bolted up. New hardware was used since there are no captive nuts.
Next, I added the coupler and tubing joiner/sensor bung. The stock lower radiator hose was used on the upper location after being cut down to size. The lower used a coupler, joiner, and the Dayco 81031 Flex hose. I hate using the flex hose, so I need to find a better solution.
Then I filled up the radiator with Toyota Red/distilled water and wired up the coolant sensor.
On the same day I wrapped up the install, my wife and I took the 2.5 hour trip up to Copper Mountain to volunteer at the Special Olympics Ski/Snowboard competition. Man, was that a nerve racking trip, 5200ft to 10,000ft! The whole drive I was watching that temp gauge like a hawk, but not once did we get over 210*F!
Normal day-to-day driving the temp is staying around 190*F. So far, I absolutely love this upgrade! Now I have the peace of mind where ever our travels take us.
Very nice install!
But your right, really no need for this but overkill is always good. My stock system handles the Rockies just fine, thats wheeling in 4lo up to 14k feet.
Normal day-to-day driving the temp is staying around 190*F. So far, I absolutely love this upgrade! Now I have the peace of mind where ever our travels take us.[/QUOTE]
BAM A LAM...I OWE YOU A DRINK OF CHOICE!!! THIS IS THE KIND OF INFO AND THREAD THAT HELPS EVERYONE AND ALLOWS OPTIONS!!
So this has less surface area than stock and cools better? Doesn't seem to make sense. It's heat transfer area that's important not fluid volume.
Nice addition! Overkill, but I do love overkill.. Mine next? lol
Absolutely, it's totally overkill. I'd be happy to help with installing one in yours!
Frontal surface area isn't everything in that equation. The extra thickness (i.e. cooling fins) helps with heat transfer too.
BAM A LAM...I OWE YOU A DRINK OF CHOICE!!! THIS IS THE KIND OF INFO AND THREAD THAT HELPS EVERYONE AND ALLOWS OPTIONS!![/QUOTE]
Why, its for ricers! LOL. Even my 400+whp Turbo talon dont need an aluminum radiator.
Why, its for ricers! LOL. Even my 400+whp Turbo talon dont need an aluminum radiator.[/QUOTE]
I'm a weird faaack. Somethings I don't go over kill on...some things I do. This would have been one for only another $75.
Creates a nice install thread that will show up when people search radiator issues. The best is breaks up the normal Kool-Aid on here of Denso, OEM, Denso, OEM, Denso, OEM. hahaha
Yes I drank the Denso and the Bilstein Kool-Aid and luckily they had not dumped the Cyanide in yet!!
Man this is awesome. Good job and great post. I hate the stock radiator with all the plastic components. One time when I was driving through the woods here in South Carolina there was a perfectly placed branch that some how made its way to my radiator (I was going a reckless speed!) and it cracked my radiator. I have always wanted to do an upgrade to a solid metal radiator. Ya its over kill for cooling but it is stronger, lasts longer, and another reason to show off whats under your hood.
I will say this, it looks like that is the only mod you have done under your hood?! Where is the IRS delete, deckplate mod, dual battery, etc! You picked an interesting first mod there.
I must have missed why you went with the model number that you did, when they make one specifically for our trucks: Part Number CC1998.
I just installed mine over the weekend, and it was pretty much plug and play. I had to enlarge the holes in the core support about 1/8" per side, but then it bolted right up.
It's made in China, but not a bad deal for $198.
Very nice install!
Hey Jay, is that stock radiator without any auxiliary cooler? 4lo absolutely roasts tranny temps for me. That's awesome you can run 14k and stay around 200F?
Hahaha, you're right. My engine bay is a disaster right now (other than the shiny new parts) and I really need to give it a deep clean. I've been on YT for a looooong time just never a poster, so I've been modding the 4Runner since '06. I've done the deckplate and ISR already. I did my ISR internally, so it still looks stock from the outside. I've been meaning to re-do it lately and you might have twisted my arm. :rockon: Hell, if you have a SC for sale, I'll keep modding my engine bay!
To be honest, I couldn't find CC1998 anywhere when I was looking. I even called Champion and a few other companies about a radiator for the 4Runner and no one said they had them. It looks like a great replacement, but I'm still happy I did the EC433 for the extra coolant capacity.
[MENTION=115770]Atomic6[/MENTION]
If I had a S/C for sale that would mean I had two S/C's!!!
BTW I do not have one :crybaby:
I just bought the CC1998 and am ready to install it...how did you enlarge the holes in the core support? any other tips? going to try to install it myself, but have a couple of mobile mechanics on standby just in case.
All aluminum radiator
How did install go and where did you source radiator from? These are made in China? Doesn't that give anyone pause in terms of quality/reliability?
Shroud
Why sell a plastic shroud with aluminum radiator in which the purpose is not to have plastic for fear of melting?
They are not made in China. That is wrong. The Champion radiators are manufactured by Champion Cooling Systems in California. Google it. It was only a little more to get an all aluminum instead of an OEM plastic/aluminum. Here is a photo after installation. Had to bend the hangers on the new radiator to fit, and widen the mounting holes in the truck. From reading other posts and watching YouTube videos, I knew this would be the case. But it was worth it, When I took the skid plate off, it was a mess. Cleaned it up and painted it . Had to bend the hangers out of the way on that as well because the new radiator is thicker and not quite enough clearance to hang it. All in all, Im happy with with the install.
Philthyphilthy
