fishrod
Just wondering if anyone has seen this problem before. When driving at night and I turn the high beams on, all the headlights go out. Not cool at 100 and whatever k's an hour.
I can however pull the lever back to "flash" the high beams on without a problem.
Turning high beams off switches back on the normal headlights.
Im thinking its just a loose wire/connection in the lever on the steering column, but that looks like a bit of work pulling it all apart.
I once owned a ford which did the same thing (cept sometimes the lights wouldnt come back on at all until you stopped the car) With the ford, there was a relay switch (kinda like a fuse) under the hood which needed to be "reset" simply by pulling it out for 10 seconds and plugging it back in.
Im pretty sure this is an issue with the lever behind the steering wheel, but thought id ask if anyone knew about any possible relay switches which might do this in the 4runner.
