All Pro VS Spidertrax wheel spacers?
i have the spidertraxx 1.25"- no issues..i think they both are high quality and trustworthy..the all pro iirc are a bit thicker and a tad cheaper..either one are good
I am sure if there is a difference you would never really be able to tell. You can't go wrong with either brand.
Is there much of a difference here? Both are lug and hub centric. Any pros and cons?
I have had the spider-traxx for over 5 years now, not a single issue. Both brands are good. I think Amazon may have the spiders in their "PRIME" membership if you are looking.
I really cannot think of any cons for either. They both do the job and I don't think i have read a single bad post about them in the forum.
I would recommend the spiders, but that is because I use them.
There is another brand, Rugged Ridge that I found for our vehicles. I as well am trying to decide what brand to go with.
So there is no difference in how they bolt up?
No, there should not be any difference.
they slip over the studs from the hub, then put the nuts on the studs (pay attention to the way the nuts go on) use lock-tight, tighten up the bolts and that is it.
Thanks for all the replies. The reason I ask is because I am buying a used set for $150.
With the Canadian dollar being as bad as it is right now, ordering a new set online is out of the question.
I did the AllPro's, since I bought a bunch of other parts from them at the same time. I also got a set of their "ET" (extra thread) jug nuts for them. I feel much better having that much more thread engagement when torqued down...
johnnya
