almost hit somebody last night. Need suggestion for lights
From what I know, HID lights are illegal in any vehicle that didn't come from the factory with them. Not 100% if that's the law in every state and in all honesty, no one cars and I don't think cops know the laws on them. HID is great for low beam but not high beam for us without modification. For us, the high beam voltage is cut and the high beam bulb is used as the DRL. Cutting voltage to the HID will fry it. If you do install HID high beams, you have to disable the DRL function. We also have plastic fog light housings. HID lights run very hot and it's possible to melt the plastic housing due to this. The LED lights are just as bright as HID in my experience but they don't project as far down the road. For a fog light, that's fine since fogs are for close range anyway. I may eventually install LED low beams but I will leave the high beams alone.
Good to know--I am old and old school so some of the mod I see here are puzzling to me! Thanks for the info.
This happened to me when I 1st got 4r but mine was from fricking limo tint previous owner had GD I don't know honestly how this dude saw anything !Lights wouldn't have helped :tinfoil3:
Lot of 'tude in the responses....but there is another factor as well. We don't all see the same in low light, so what is plain to one may be tough for another. I had Cat's eyes until I had Lasik and suffered a drastic reduction in night vision thus requiring more light to ''See'' the same picture at night. Age also reduces night vision.:eek:
No attitude meant in my post. Not trying to beat the OP up. Also at age 50 my night vision is no longer what it used to be. :)
Here are the pictures I said I would post. ... Sorry for the sideways pictures,....
If I were looking with my head sideways last night, I would have seen them :)
Thanks for the pictures! Two pictures are worth two thousand words, I am sold, This is exactly what I was looking for--some sort of low flood light to the side. I also managed to locate an old thread on how to adjust aiming of the fog lights so I think I am all set.
Thanks again!
Side-Facing Lights - Legality
I have Truck-lites with very good spread, but visibility on the side is still poor; I think partly because bright headlight beams makes us less sensitive to darker light on the sides.
I'm contemplating adding side-facing turn assist lights (It helps that I have a first-gen that's easy to modify).
1) They would use same or lower power bulbs than turn signals so as not to outshine the latter (i.e., turns use 1156 bulb, I'll use 921's).
2) They would be mounted low, i.e., on the bumper, to further prevent them from outshining turn signals, yet light up lower part of pedestrian / or object on the side into which I'll be turning.
3) It would come on only when I my turn signal for that side is on.
Any idea on laws about that? I searched but found nothing.
Which high beams did you go with?
9005(HB3) Led Headlight Bulb All-in-One LED Conversion Kits High Power 8000LM 6500K Xenon White
Sold by: CALAIS
and for the led fog lamps -
Calais Extremely Bright COB Chips H11 30W LED Fog Light Bulbs Plug-n-Play(pack of 2)
Sold by: CALAIS
Thanks again!
Could you link that old thread?
I searched unsuccessfully for a thread of fog light adjustment for 5th gen's... :ranger:
:thanks:
Xenon Depot Low/Highs
I picked up my 2018 Trail and within 5 days ordered some Xenon Depot HID lows and LEDs highs. I commute on I80 through Wyoming for work. The speed limit is 80mph and the threat of hitting livestock or elk is very real. Going 80mph out driving your headlights is a real possibility. I went with the Xenon Depots and could not be happier with them. I purchased the CANbus with the high beam kit so I can still use my DRLs and they do not flicker. Customer service was awesome and they shipped them with free two day air. Check out a couple of blog post's linked below (MTN4RNR and SwellRunner as they have good tips on sealing the headlight housing to prevent condensation in the housing and placement of the drivers. There are also a bunch of YouTube Videos specific to 5th Gen 4R. There are several different color temperature hue's you can purchase for the lows. I purchased the 5000K temperature for the lows as I didn't want crazy uber white borderline purple color temperature and it matches the highs better.
Xenon Depot:
1) High Beams 9005 XTREME LED PRO HEADLIGHT KIT
9005 LED Headlight Kit | 9005 LED high beam Upgrade
2) Low Beams H11 HID KIT | XTREME HID
H11 Xenon Conversion | XenonDepot Xtreme H11 HID Kit
Blogs:
MTN4RNR
H11 HID Headlight | 2016 Toyota 4Runner HID
http://www.toyota-4runner.org/5th-gen-t4rs/209558-building-driving-adventuring-mtn4rnr.html
SwellRunner
https://swellrunner.com/2017/10/31/factory-lighting-was-terrible-time-to-fix/
DEFINITELY recommend sealing the grommet with silicone for extra condensation protection.
I first had some white LED fogs, they threw light all over the place, I think some one here called them squirrel finders. Morimoto? Effect was cool when it snowed but usually not too many cars up in the trees. Then I got yellow LED fogs from xenondepot.com. They throw the light side to side. Hardest part was trying to figure out where to cable tie them up to the frame. I bought a variety pack of black cable ties from Amazon.
You might consider getting white LED fogs, think XD sells them too.
Thanks again!
These are the bulbs i'm running in my fog lights
https://www.ebay.com/itm/LED-Headli...ash=item4b2c3380df:g:z1sAAOSwr1tZ~e4v&vxp=mtr
I had the same issue and disliked the light output from my stock halogens headlights from my 13 4Runner. I ended up doing a projector retrofit with big LS projectors with HIDs and it made an unbelievable difference. Here are a couple comparison shots from years ago.
wayblom
