Alternative to Fog Light Stalk Switch?
THatfield
Hey guys,
Looking into getting some factory fogs, but I have a quick question. Do I have to get a stalk with the switch or can I get a Toyota Switch and put it in a blank and wire it up? I can't find any schematics or any threads that have a similar question to mine.
70 bucks is a lot of money just to gain a factory switch, especially when im already dishing out some dough for the fogs. I wouldn't mind putting a Toyota Rocker Switch in a blank spot, but I just want to make sure its possible to wire up. Obviously with me getting factory fogs, I'm going to use my factory plugs by the bumper.
I tried to explain this the best I can, hopefully this makes sense because I feel like I'm not. Haha.
Thanks for any help.
I have a 1999 and at one point explored getting the factory stalk for the fogs - way too much $$$ for it though. Some have had luck pulling it from a yard (if you have one nearby). I did find a set of instructions on yotatech (can't find the link right now - I believe I have them at home) about how to use a factory switch in place of the stalk. They include which wires to tap, etc. I will see if I can dig them up later today.
Thanks for the reply! I'll hop over to YotaTech and see what I can find. :keyboard: If I can find the link before you reply, ill post up so you don't waste your time!
Thanks!
This is perfect I just have no idea what wires I need to relocate from the harness going to the stalk to the rocker so that the rocker controls the factory fogs.
my other plan was to buy a hella micro DE kit, but then i wouldn't have the proper brackets to mount the fogs would I?
I haven't done a fog light install yet. However I would imagine that by using this switch, you won't even have to fool with wires from the stalk.
As the picture states:
One terminal gets 12v feed from the fuse box (I recommend 12V with key on)
One terminal goes to ground
One terminal goes to the relay for the fog lights
The typical 4 terminal relay will get 12V, Ground, the wire from the rocker, and a wire to the fogs.
I hope my memory is right, lol
The only reason I would mess around with the factory wiring is because the factory fogs would plug right in to the plugs Toyota left taped up by my turn signals that are for fog lights.
If normal (not factory) Micro DE's would mount to the bumper easily, I wouldn't mess around with any of this, but it looks like from looking under the bumper there isn't anywhere close to mount the DE's to, which makes sense as to why you practically need factory fogs and mounts to be able to use the slots in the bumper next to the turn signals.
This is what you need. I installed a switch in my 2000 to tap the factory wiring and this is what worked for me.
Fwiw i now would prefer to have the stalk because im out of switch blanks for more stuff.
http://www.toyota-4runner.org/3rd-gen-t4rs/95832-hella-fog-light-installation-instructions.html
That thread is a gold mine. Thanks!!! :hail:
I would be worried about switch blanks, but I don't plan on modding too heavily (yet) so for now this should please me. Haha. :jump:
ghengiskhan
