JLC84cam350 New member Sep 23, 2010 #1 installed a small block chevy and know i need to know what the pluggin on the alternator is for and if i can reuse them on the chevy alternator
fourwd1 Moderator Sep 24, 2010 #2 On the 3-pin connector- Yellow wire goes to B terminal White wire goes to S terminal Red wire goes to IG terminal Single heavy white wire is out to batt Match them up to same terminals on the GM alt. Or get/convert to a one-wire alt, that's how I did it on my 83.
JLC84cam350 New member Sep 24, 2010 #3 fourwd1 said: Single heavy white wire is out to batt . Click to expand... you mean the ground that does to the negative side of battery
