alternator rebuild kit
jmsdad
Alternator whine/bearing noise on my 96 4runner. I replaced with one from my parts bin. I would like to rebuild the bad alternator and keep it for back up/spare parts.
I see some rebuild kits online. Has anyone done this and is there a preferred vendor?
Thanks in advance,
Tom
Thanks in advance,
Tom
Sub'd for info. I want to do the same thing with my old OEM alt.
My original alt died after about 320k miles. The copper sliprings had worn through. Unfortunately, they are very expensive to replace, thus making a rebuild uneconomic. The best alternative is to buy a toyota rebuilt alt.
Yes, if you have armature damage, its not worth fixing. Same would go for a cracked case. Probably best to verify the alternator is worth rebuilding before buying parts.. I agree. :-)
There should be a jobber number on the bearing seal which is the part number to order and then just get the brushes at the dealer.
For the 70a Alt I have the bearing sizes as another way to order them.
I am wondering if the 90 amp ones Have a different bearing, brushes and regulator. etc.. As i have both 70amp alts and 90 amp alts in my fleet. Looks like I need to tear a few of those apart and figure these out rebuild etc. I have many around here of both..
