Amber/Yellow LED Fogs Comparable to the Katanas?
mscot
I'm finally going to do an LED headlight upgrade before winter hits and want to take care of the fogs too.
I want an amber/yellow LED bulb that compares to the Katanas (i.e. great value and essentially the same bulb as what other companies are charging 2+ times the price).
I do not want laminX, I'd love Baja's new SAEs but I have to be realistic on how often they'd be use.
I do not want a white bulb for fogs.
I've considered just getting the PIAA H16 halogen ambers since I know they'll heat up any ice but I'd like to get the light output of LEDs.
Does anyone have any recommendations?
TIA
Thanks but that’s not what I’m looking for.
Just want a rec for good quality led bulb replacements for around $50
I don’t have a recommendation on bulbs, but I really love amber / yellow lighting in my fogs… I use them a lot and to my eyes that made a huge difference.
I'm not sure you can get similar brightness to the Katanas with "yellow" LEDs. Mind the Katanas are the brightest cheap LEDs for projectors while the Nineos are the brightest cheap LEDs for reflector headlights(BulbFacts | Aftermarket LED Kits Chart - Comparing to Halogen in Reflector Headlights & Foglights)
You could try the BOSLLA Bullet (Boslla Bullet Series H8/9/11 - The World's first 4 Color LED Headlight - Boslla) and change the mode to 'Yellow' every time you turn on the fogs, but that may be annoying.
I personally used a couple layers of amber and gold colored films, paired with the KASO LEDs(https://smile.amazon.com/gp/product/B07P3HZB7D/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1)
You could also try some of the cheap JDMASTAR or ALLA Lightning yellow LEDs and return them if you don't like them(https://smile.amazon.com/Alla-Lighting-H11-Illumination-Replacement/dp/B07GTC42CL/ref=pd_ybh_a_3?_encoding=UTF8&psc=1&refRID=XYNYACK5E04NFVQA327A)
Thanks. I was looking at the Alla's. Have you heard good things about them?
My issue is they have 5 different H11 yellow bulbs and I don't know which one to pick.
TIA
If you are interested, I’ve got a set of yellow H11 Diode Dynamics SLF bulbs for sale. PM me if you want more details.
