Amps Under Seats of an 02'?
kestrel1
I'd like to put amps under each of the front seats of a 2002
4 Runner. However, in the floor below the passenger seat there's a round cut out with what looks like a fan vent, although I can't really see if it contains a fan or not. Does anyone know what this thing is, and will it create problems if I put an amp over it? Thanks.
its the vents for the rear heater, of course.
i would put them on the back of the rear seats in the cargo area.
thats where i mounted mine:
I put an amp under the driver seat of my 2000 with out any problems. My rear floor defrost is closer to the center console so i could put an amp under either seat.
Matt
your 2000 doesnt have the rear heater though... which is bad for the amp to be on/near.
The vents for the rear seat passengers are on the center console, on the end aimed towards the feet of the rear passengers. The amp is under the driver seat, a few inches in frront of the vents and the vents are not pointed at the amp. I think it's safe.
hmm, ill take a look under my seats again, but from what i saw before my amp's install, it didnt look like a good idea.
ill post after i take a look tonight.
I am just about to install my stereo in my 99 SR5 but am stuck on where to mount the 2 amps. I have been considering one under each seat because of the added security and that I plan to do alot of camping and want to have a nice flat surface when I put the back seats down (possibly going to be sleeping there :) ).
I am however worried about air flow (had problems with my PPI overheating when in a tight space) and wonder if anyone has other options... Is there room to be made behind the side panels in the cargo area???? just a thought as I have seen 4th gen ones have their stock amps in there...
Any suggestions would be great.
i have one of mine mounted on the sub box itself in the back, so if i need the room i can take the whole thing completely out. and im going to mount the other one when i get it under the drivers seat. theres room, not much room though, just measure what you plan on getting first before you do it.
what did you end up doing?
Hey There,
I am in exactly the same position - I have a 99 SR5 that I am looking to install a new system in. I have the rear heater (where the fan occupies the space under the passenger seat) and I would rather not have to mount the amp directly to the back of the seat for cargo/camping reasons.
What did you end up doing here?
Thanks!
-James
