Android auto won't work
pleasehelp
Hi I've rented a 21 plate 4runner and can't get Android auto to work I've connected Bluetooth and connected a cable to the USB next to the power socket under the display occasionally it says disconnect and reconnect but nothing happens. It works fine in my e class
Any ideas?
Any ideas?
Go into the settings and activate it.
Cheers any heads-up on how to reset it? I will try pick up a cable somewhere I brought 3 usb-a to c cables and yeah 2 don't even connect one does but has the above issue
You are not alone. This is the post from Android Auto staff to solve the problem. Even it's not work with me, Hope it can help you, because it is free.
[FAQ] Can’t connect or stay connected - How to diagnose/address the issue - Android Auto Community
My solution was to buy an adapter. Actually i do not need a wireless connection, what i need is stable connection. Even disconnection few times after i use adapter, it is already better a lot than before.
Blow Link is where i bought it, it is work well. Amazon also have a lot.
American Express
The discount code is SMART15 which is i used successfully, after discount is $80+. I've asked them and every one is able to use the code.
seltzernator
