Another 4WD broken thread
FIXED!!!
I found the issue - a broken wire. One little wire with all this hardwork. Crimped it, soldered it, repaired it and 4wd is back online. I shifted in and out of 2HI and 4HI, but I am going to avoid multi mode for a bit.
YouTube
Here is a video I found while researching that contained some good info on how toyota T-cases work. The video is for a 01-04 Tundra I believe, but it uses the same actuator and front actuator as the 01-02 4Runners. 99-00 4Runners with multimode use a very similiar system.
Right on man!! Would you mind posting a picture of which wire it was that was broken!?
What wire was broken and where?
Didn't take a pic, but if you follow the wires that come out of the transfer case actuator plug, they meet up with the two sensor wires and form a bunch that goes towards the front of the car. Where the actuator plug wires join the sensor wires, I had one that was on the outside of the group that seemed to have been ripped by something. I repaired it and now my 4wd seems to be working fine. I left the multimode switch unplugged - after looking at the way our transfer cases work I decided to not use that anymore...
Why? Multi-mode is great for 'mixed' conditions - snow/ice conditions with some clear pavement, etc.
-Charlie
I don't like the design of the multimode system much, and it seems like it tends to break when other people use it. The way that the actuator actually engages in multimode also is kinda strange. I think I'm just going to leave it unplugged and deal with it. Makes driving on those mixed conditions a little more interesting anyway.
chasebradshaw
