4WD Problem, Blinking lights (aka Limbo mode)
KudoCl
All inputs are appreciated, thanks!
Vehicle: Toyota Hilux Surf 1997 SSR-X
Transfer case: J-shifter with 4WD button on the side, aka Multi-mode (either VF2A or VF3AM)
J-shifter: 2H-4H > 4H(L) > N > 4L(L)
Center differential: Engaged manually by pulling back on the shifter. I DO NOT have a button for it.
Problem: The center differential is stuck in the locked position. I can shift from 2H to 4H, but when I'm in 4H, there is driveline binding when turning indicating that the center differential is locked, and the 4WD indicator lights are blinking. When in 2WD, the lights are off. When I put the lever in 4H(L)/N/4L(L), the lights turn solid and light up according to the position, as they should.
Question: I can't find any clear diagrams or videos of how the Center diff mechanically locks and unlocks. My assumption is that there is a fork on a rod connected to a sleeve. If that's the case, could the fork be disconnected from the rod in the locked position, making it impossible to operate with the shifter?
What I checked so far. The list is extensive since I troubleshot two problems at once, so feel free to use Ctrl+F to find something:
- Checked 4WD fuse = good
- Tested all switches for continuity on the bench while pressed in as well as on the truck = good
- Tested VSV actuation and checked ohms = good
- Tested lines to see if they hold vacuum = good
- Tested continuity on 4WD button = good
- Applied vacuum on lines and hand-turned the front side of front diff (since drive shaft was off) = locking/unlocking fine
- Tried the same thing but with the 4WD button pressed/depressed while truck running = locking/unlocking fine
- Tried jumping the actuator in and out of 4WD and turned the t-case side front drive shaft by hand = locking/unlocking fine
At this point, I assume the problem is coming from the rear and that the ADD relay is functional since front is locking as it should. I put the front drive shaft back on.
- Opened the t-case actuator = no corrosion
- Took actuator apart, cleaned old grease, then put back together with new grease, unsure of the timing of the big gear since it fell when opened.
- Tested to hear if actuator motor is turning when button is pressed/depressed = no sound if in limbo mode but works when the truck knows where it is situated (like when in 2WD until it hits 4WD)
- Tested wires continuity between plug at the actuator and plug at the 4WD ECU = good
- Manually put it in 2WD with jumping wires, did a short drive = lights stopped blinking
- Swapped out 4WD ECU and tried engaging 4WD = lights started blinking again
- Changed the 2 switchs on t-case actuator = problem still occurs
- Reopened t-case actuator, clocked it using picture found online = i can now shift in 4WD but same problem as before with the binding when turning and blinking lights.
Edited the post since the original one was not clear.
Hello again, I found the problem, which, for me, was two problems at the same time, making it really confusing to figure out.
I had time to revisit my problem and I checked my switches that I had swapped out. Turns out one of the switches was working 3/4 of the time, explaining why sometimes it would work and other times it wouldn't.
The second problem was the main problem and harder to find. I opened up my actuator again and retested the continuity between the spring pins on the cap and the plug on the other side of it. I had already tested this before with good results, but now I took the time to test it while dragging my multimeter lead to multiple places on the pins. At one point on one of the pins, it lost continuity at a certain spot. No corrosion or visible damage; I sanded the area and cleaned it, retested, and it was good. Then I retimed my actuator, put it back together to test, and voilà, it's now working!
I also figured out that the center diff is in fact engaged by the actuator. The selector shaft positions are the following:
Out = 2WD
In = 4WD
Middle = 4WD Center diff locked
The pin was losing contact as it was turning, making the actuator stop in the middle position, locking the diff. Then it had a hard time coming back out of it since the pin had contact 1/10 of the time.
Hopefully, It can help a few by concluding this post. I'll keep an eye out if anyone has questions about their problem or the process i took to resolve mine.
I'll also make another post that i will link here about how i successfully timed my actuator since i know it's a big question in the community, i know i searched quite alot to find half of the answer!
o7
Nice summarization and Thank You for bothering to follow-up to complete this journey.
Like many on here - I learned changing the various diff fluids and using the system regularly goes a long way to keeping it running. Luck and enjoy the Runner.
CeasarNPrawns
