Another Projector retrofit
gshadow325
Project Quad Bi-Xenon retrofit
I dont know what i am going to do with it until i get to that part.
Had these Hella E55 bi-xenon projectors for years.
20131128_103851_zps864b166c.jpg~original
[/URL]
So [MENTION=55855]zopperman[/MENTION] suggested that i do a retrofit
He suggested i take advantage of a black friday sale from trs.
Ordered the following
-Gatling Gun 2.0 shrouds for my Hella E55 projectors
-Morimoto Mini H1 6.0 Projector
-Pair of Eagle Eyes headlamps
Bought following parts
-DAP Silicone something 230
-JB Weld putty stuck with 5 minute cure time
-SEM Landau Black spray paint
-RED SMD Led for demon eyes
-HI-Intensity LED strip for DRL
-3M Metal tape
E55 next to morimoto mini h1
20131205_174052_zpsba269bc0.jpg~original
[/URL]
3" projector on left, 2.5" on right
20131205_174057_zps3aab1a04.jpg~original
[/URL]
Gatling Gun 2.0 shrouds on both projectors
IMG_20131207_135702_zps8xhwetbi.jpg~original
[/URL]
RED SMD for the demon eyes
20131216_100736_US30_zpsd4a65531.jpg~original
[/URL]
LED DRL strip and test burn in of the HIDs
Eagle eyes came in $80 per pair on ebay shipped
20131216_160503_LancasterAve_zpsad6b06f5.jpg~original
[/URL]
took 10 minutes before i opened it and used a heat gun and popped it open in 5 minutes
20131216_161746_US30_zps3dfeecfa.jpg~original
[/URL]
headlight bezels
20131216_163607_LancasterAve_zps5ece0624.jpg~original
[/URL]
3" hole saw. hole saw meet bezel, bezel now has a hole
20131216_163610_LancasterAve_zps9288da28.jpg~original
[/URL]
20131216_163650_US30_zps19461a40.jpg~original
[/URL]
20131216_163855_zps3c6364f4.jpg~original
[/URL]
20131216_163859_LancasterAve_zps0893abf7.jpg~original
[/URL]
Parts everywhere all over the place
20131217_085047_US30_zps425b65f9.jpg~original
[/URL]
Bezel painted. projectors test fitted.
20131217_175130_US30_zps4146b670.jpg~original
[/URL]
thats it for now. waiting on some smaller shrouds from trs for the bi-xenons in the hi beam buckets
today 12/18/13
20131218_120649_MerionAve_zpsd2cd8580.jpg~original
[/URL]
working on passenger side headlight right now.
12/20/2013 added
today TRS shrouds came in. so i closed up one of the headlamps. then started on the second one.
pointers
-1000 grit snad paper and some water will scuff up the bezels nicely so you can black them out.
-make your holes. test fits BEFORE you paint the bezels. this way you dont scratch them up moving it around.
-i used SEM landau black spray paint
here are the two "eyes" in the headlamp bezel
now its in the headlamp housing
20131220_151133_US30_zps898e0330.jpg~original
[/URL]
20131220_151138_LancasterAve_zps4884d3ac.jpg~original
[/URL]
closed up. go buy some clamps. small $2 from home depot or lowes. makes your life a lot easier. Also no oven was used, just a good ole heat gun. it was open in 3 minutes. closing it up too about 5-7 with a head gun too.
20131220_152935_US30_zpsf90fe742.jpg~original
[/URL]
20131220_152945_US30_zpsb1536f44.jpg~original
[/URL]
20131220_160550_US30_zps2d6d4da3.jpg~original
[/URL]
20131220_160605_US30_zps0f5130bd.jpg~original
[/URL]
Too much reflection so the pictures dont look as sexy as they do in real life.
both projectors are set level with the old halogen lowbeam lamp. was going to take pictures but my cell phone was running out of batteries so tomorrow going to work earlier to finish up the other side and take some more pictures.
12/21/2013 update
More detailed pictures
Headlight buckets with the two projectors installed
20131220_150829_MerionAve_zps5bacbeec.jpg~original
[/URL]
Headlamp shroud painted.
NOTE: Use a head gun to apply the paint. speed up the dry time by 10000x. thin multiple coats!
20131221_075528_LancasterAve_zps33f6235f.jpg~original
[/URL]
If you wanted to see what the headlight mounting looks like
20131221_084607_US30_zps6e869cbc.jpg~original
[/URL]
Headlight lense with bezel in it.
NOTE: head lamp comes off in two piece. then into 4. first two halves is lense and bezel together
20131221_084453_LancasterAve_zps0d36ac5c.jpg~original
[/URL]
20131221_084445_LancasterAve_zpsa570214b.jpg~original
[/URL]
Headlight bucket inside headlamp mount
[/URL]
[/URL]
Use this stuff in the picture to make a good tight seal
20131221_090400_LancasterAve_zpsd88f1cc7.jpg~original
[/URL]
I routed my "mods" thru the moisute/air vent holes in the top and bottom.
20131221_084719_US30_zps4f1be6c0.jpg~original
[/URL]
20131221_084724_US30_zps4b3871cd.jpg~original
[/URL]
Mods thru hole
20131221_085023_US30_zpsdc24985b.jpg~original
[/URL]
Notch the tab in the hole so the wires dont get pinched.
20131221_085112_N52ndSt_zpsed89371e.jpg~original
[/URL]
reserved just in case, needed it
Cap reinstalled over the wires :)
20131221_085128_US30_zps12d608e4.jpg~original
[/URL]
what the rear looks like. used some silicone to make a gasket to fill the void left from cutting off the hi beam headlight holding part. thats the white stuff around this picture. it dries clear
20131221_130216_LancasterAve_zps5029e0f5.jpg~original
[/URL]
dont need it on the low beam one, since it gets good seal anyways
20131221_130220_LancasterAve_zpsb9e2c013.jpg~original
[/URL]
Progress. into the truck. I have female hi beam connectors so it can just plug and play into the hibeam wiring.
20131221_133913_US30_zps0846f6f0.jpg~original
[/URL]
Low beam demon eyes
20131221_082844_US30_zpsec45accf.jpg~original
[/URL]
Quick installed picture
20131221_160439_US30_zpsacd8bd6b.jpg~original
[/URL]
Headlight cut off from 50feet away. spare tire messes up my beam pattern LoL
20131221_170428_ReedSt_zps32f1b9af.jpg~original
[/URL]
Here is what the front looks like before. the tire is still on the front
20131221_121903_LancasterAve_zps4fa3e8fc.jpg~original
[/URL]
Finished install pictures
12/27.2013
20131227_170605_zps41409b71.jpg~original
[/URL]
20131227_170536_zps580f7f77.jpg~original
[/URL]
20131227_170531_zps26faa7b2.jpg~original
[/URL]
20131227_155708_zps081589c2.jpg~original
[/URL]
20131227_155646_zps0c482cc6.jpg~original
[/URL]
20131227_155608_zps135dd918.jpg~original
[/URL]
20131227_142824_zps5b00925b.jpg~original
[/URL]
20131227_142819_zpsaed08b5c.jpg~original
[/URL]
20131227_155754_zps4165005c.jpg~original
[/URL]
Looking really good. Can't wait to see the finished product. It looks like the E55 projector is larger than the Morimoto but it's going in the smaller 'high beam' headlight bucket? Just wondering if that's just your preference or if mounting depth or any other factors came into play. Also - how do the eagle eye parts compare to OEM? I was under the impression OEM units were better built and preferred for these retro projects. Obviously the cons being more expensive. I don't have any first hand experience with aftermarket units though so it's all based on other folks feedback.
Not questioning your decisions, btw - just curious as to why so that when/if I do a retrofit I'll be better informed.
The demon eyes is a cool trick. I think Zak did that too, right? Keep up the nice work!
eagle eyes are junk. they cheap and they serve a purpose. to be retrofitted LoL.
teaser pic. no morimoto in yet since the gatlin gun 2.0 shroud is LARGE so a mini gatlin gun shroud is enroute from trs right now.
[/URL]
That looks pretty badass! Any pictures of just these bad boys lit up in the housing?
20131216_093214_LancasterAve_zps26b297b8.jpg~original
BTW, I think you mentioned you work at a shop right? Do you work on anything else besides your own truck at work? lololol :jk:
Yeah I do this in my free time, lol. Been raining here in Vermont and been overcast. Since I'm on vacation didn't have time to take it. They look bad asssss
Cost for project retrofit
Materials and cost breakdown:
Sealing and paint and stuff:
  1. DAP Dynaflex 230 $5 DAP Dynaflex 230 Sealant - White 5.5 oz
  2. SEM Landau Black Spray Paint $10. something i have in stock Buy SEM Paints Color Coat - Landau Black Aerosol SEM15013 at Advance Auto Parts
  3. 3m window weld sealant $15 3M® 8610 - Window-Weld? Round Ribbon Sealer | O'Reilly Auto Parts
So about $30 in materials that is enough for you to do a life time of retrofits. I also bought some long 8/32 x 2" truss head bolts and nuts to install my E55 projectors $4
Hard parts this is where YMMV(your mods may vary)
  1. morimoto mini h1 6.0 projector kit $120 comes with shroud choice Bi-xenon: Morimoto Mini H1 6.0 - HID Projectors from The Retrofit Source Inc
  2. Your favorite HID kit from ebay. ddmtuning ect and in your favorite color. I did 6000k H1 $85
  3. OEM BMW 550i headlamps harvested the Hella E55 projectors, free. trs copy $150 per pair and no shrouds. i used gatlin 2.0 on mine Bi-xenon: Hella EvoX-R - HID Projectors from The Retrofit Source Inc
  4. Eagle Eye Reaplacement headlamps $79 ebay, New 03 05 Toyota 4 Runner Headlights Headlamps Pair New Set | eBay
  5. trs gatlin gun 2.0 shrouds for my bmw projectors $40
  6. red led for my demon eyes $5, free since i had left over from previous project.
  7. LED light bar $90
So bi xenon retrofit price, not including mods
QUAD pricing $560
Single Bi-Xenon $285
Price difference between the two retrofits is the cost of the second projector and hid kit to go with it.
NOTE:
Quality of the eagle eye headlamps is cheap. it serves a purpose. to be a organ donator
HID kits can come cheaper and more expensive. so your price will vary from mine
Demon eyes, halos, angel eyes, ect all these mods can jack the price up.
Just for reference, since if i had to duplicate this retrofit, it would cost, no labor almost $600 for quads and $350 for bixenon.
QUAD pricing $560
NOTE:
For the demon eyes how many SMD strips did you use and how did you mount them?
