Antenna Stuck!
skythefly13
My antenna is stuck in the up position and wont even budge when the T4R is started and killed. I am able to push down the antenna to about half way but it wont move past that. What can I do to fix this!!!
antenna motor isn't working. Do you have an aftermarket deck? If so, pull it out and check to see if the remote wire is connected.
I think it's working, every time the engine is started or killed you can hear the motor just running and running but it must not be catching on to something?
That solves it, get right to the point. I had the same problem with my celica antenna, you hear grinding but it doesn't go all the way down. Just follow his post.
