Any 4Runner Experts Out There? (P1300)
the1998sr5
Hi fellow Toyota gear heads.
I have had a misfire for a 3 weeks and I swear it is going to drive me insane.
It happened 1st time while wheeling, I went through a bog (maybe 2.5 feet)- and the engine misfired for about 10 minutes. Check Engine light flashing. Then it went away until the next time I got the truck wet.
Wheeling a month later, (same thing) went through a small river and it began misfiring. Check engine light solid this time.
Ran codes and got an ignitor (or ignitor circut) code P1300. I changed the plugs and wires and cleared the codes. Cranked it and it is still missing, check engine came back on 2 days later.
Went to Toyota and they said the codes are usually very acurate so I should change the ignitor. I swapped one with my buddies 4 runner and it made no difference.
I brought it to a shop who checked the compression (it was excellent), and the injectors and no luck there.
I thought it could be the coil packs, but Toyota said I would have a more specific code (ex. cylinder 3 and 5 or ignition coil)
So I have not driven it or wheeled since then (I do not want to burn up the cats). I have a few dollars to spend, but I really could use some help here.
Does anyone have any ideas? Or even suggestion of a good shop in North NJ?
Again, I'm really getting desperate I looked for a year to find the perfect t4r and now I can believe its been so long since I drove it.
166k, new timing belt, new alternator, starter, plugs, wires, ignitor, water pump, radiator
Maybe you got some water or silt in your alternator when you were playing submarine.
Make sure it is supplying a good solid 13.8V minimum.
Mine did something similar.
It sounded like A Subaru.
Same. Plugs & wires. Nothing. Still misfired.
Turned out to be fault fuel injector in cylinder 2.
New injector.
Problem solved.
jisoo200
