‘98 3.4 engine miss??
4xt4r
Member
Ok, I’m baffled! I was backing up in a rough, rocky area & one rear wheel came of the ground & engine revved up.i don’t think engine came close to redline & took foot of accelerator immediately. When I put in drive to go up a pretty steep paved incline I noticed a distinct miss. I checked code & came up with cylinder 2 misfire. I removed coil packs & all ohm readings were good & same. I swapped coil packs around swapped plugs around too. Had battery disconnected during process. Started & drive until cel flashed, same cylinder 2 misfire.
Thought maybe try injector next, so I Changed cylinder 2 injector with a used one that used to work fine & still cylinder 2 missfire. did compression test, numbers all over the place.
#1-200psi,#2-190,#3-205,#4-160,#5-210,#6-80.i had plug#2 laying on
Block while cranking & had a very fat, blue spark. I checked valve lash thinking #6 is too tight clearance because of low compression. All clearance were Very close to spec & none were too close. What to do next??
Why misfire on #2 when its compression is so much better than #6??
I’ve owned truck for 17 years , 294k miles.
Thanks guys!!
Tom
I would verify u r getting power to that injector. If u have a stethoscope maybe u r able to hear injector clicking. I would also check for continuity on the injector
Good luck
MikeM
Hi there, just following up to see if you've found the culprit. I'm hunting down my own misfire situation myself
wwarren702
