Any idea what this could be?
Rishi3
KbZ545r
Woke up to this, maybe something with the stability control? Everything drives and sounds normal. Going to check the codes later today.
The first thing I would do is the first on the list of codes, the gas cap, when the rubber gasket stops sealing it will trigger most of the dash lights you're seeing, get a new one, but before you buy one try pulling the rubber gasket on the gas cap and flip it over, it also wouldn't hurt coating it with a little Vaseline to help it seal better.
The second one on the list is the bake issues, first check to see if you have any stop/brake lights, if not replace the stop light switch at the brake pedal and check for brake lights again, if you do then reset the codes and see if any codes come back on, if any do deal with them one at a time.
Let us know how it goes.
What he said. Those exact lights showed up a couple months ago on my 4r, we just had to replace the gas cap and they all went away
AndiGarage
