anybody done hubs and bearings on 4wd?
Why would you buy a complete unit? You have a press. I can understand someone who uses your 4runner like you do needing a new hub. If you are pressing new parts you don't have to deal with the old and pressing the new parts takes even less than dealing with old. You can buy the exact same parts that bumper2bumper is selling from Rockauto for $120. Essentially you are saying that you are willing to pay $70 per side for someone to do the work?
I'm mainly saying I would avoid pressing out the old hub at all costs. Even talking to a toyota master tech (a good friend of mine) in his words "the toyota 4runner front hub bearing assembly is the hardest hub to press out of any of the toyota press fit hubs"
I would have to purchase new mounting bolts to install or cut the old ones out of the old bearing assembly before pressing a new hub and bearing assembly together but to be honest I really never thought about purchasing the hub, mounting bolts, seals, and bearing seperate that is a cheaper option. I just purchased the bearing and seals and reused all the other parts.
Either way they're just wheel bearings and considering the press work it takes on the rear hub bearings, having the front pre-assembled is a good time saver. Worth 70 extra bucks a side? Eh one could argue its value.
Actually, you contradicted your entire opening argument with this statement right here. That is why people who have done it are suggesting the pre-pressed assemblies. It's a matter of how much convenience you're willing to pay for and what it's worth to you. Call it lazy if want I guess. These wheel bearings can be a ***** to press out. Those that have experienced it, know right away, that a pre-built assembly is the way to go. Oh sungod... good to have you back buddy!
There is no contradiction. That is exactly what I said. Cost vs convenience. For $20 or so I would be willing to give up some hard earned cash to save a few mins, but for $200, probably not.
Even being the frugal bastard that I am, I still wouldn't buy a new assembly. I could buy all new parts (hub, bearing, seals) for $120, pay a local shop to press them and still have and extra $50 in my pocket vs what it cost buying them from bumper2bumper.
your original posts on the topic seemed as if you were suggesting its worth reusing the old hubs as they aren't really that much of a wear item just metal and some studs. I get what you're saying now.
what question?
and "OK".
Your question about not knowing why you would recommend doing both sides. Any mechanic with any skill would know that. Granted I have yet to run into the mechanic that knows everything, but that is pretty much basic knowledge. That along with your statement about Timkens being cheap bearings, it is pretty clear you are not a mechanic. Isn't the internet great because you can pretend to be anything you want?
Yeah, I am just looking at the overall picture with all the options. Clearly there isn't one best answer which was my point. Preassembled units have their place, but they are not the save all to end all solutions. With limited resources they will still work out to less than what it would cost you to take it to a mechanic and eliminate the risk of having someone like [MENTION=84120]nevada[/MENTION]working on your vehicle. If you have the resources, you can save real money.
the reason i asked that question to YOU, is because you were giving BWI a hard time for suggesting to his customers that they replace the HUB along with the bearing. something i also agree with.
but yet you come along and suggest they replace parts they DONT need.
and you can say what you want about me, i dont give a shit. :welcome:
I just did my bearings about a 1,000 miles ago. I have a DIY garage here on the base I work at. I did all the work except the pressing of the bearings but I watched and had the manual to ensure it was done right (I never do any work on my rig without a manual, force of habit from working on helicopters). It was easy task.
Wow, I am gone from this thread a couple of days and it explodes! Hahaha.
To save some space I will edit out unnecessary text in the quotes.
The reason most shops and dealers recommend the hub also is due to the tendency of the inner race to almost fuse to the hub shaft after a lot of miles. I've seen many times the inner race having to be carefully cut off with a cutting wheel because it will not budge on the hydraulic press and/or cannot even be set-up safely on the press. I've seen this happen with both Toyota and Honda bearings most commonly, but other vehicles have done it also.
As a technican I cringe everytime I see someone have to cut, hammer, and chisel the inner race off and worry about damaging the hub. So our dealership has gotten used to the habit of recommending an entire assembly to avoid wasting time and potentionally damaging a part that will be reinstalled.
Its sort of why no one really rebuilds alternators or starters anymore; its cheap to do; but most technicans don't want to waste the time and potentional issues to rebuild them when you can get a new one for a decent cost ready to go; that and some people don't even know how to rebuild them.
I agree 100%. Out of all of the Toyota assemblies I have taken apart in my shop, I would say 10% had zero wheel hub damage. (And yeah, I still have about 15 or 20 rebuild kits for the old GM alternators from the 70s. Used to rebuild them all the time!)
You saying that it is easier to just call parts is no different than the dealership that I went to and the tech call tie rod ends because they were frozen and he was too lazy to apply some heat to free them up.
The biggest problem here is that it takes very little heat applied to an already used wheel hub to render it brittle, and more susceptible to cracking. In the early 2000s there were several articles in auto publications that said applying heat to a wheel bearing race or wheel hub to assist in removing the bearing was not recommended due to potential cracking that could go unnoticed.
autozone bearing
Decide for yourself. In any case the same bearing can be found at rockauto for $40 less.
Not sure on the price specified, but that particular bearing actually varies between $70 and $80 just over the past 2 months.
There are some rules to auto repair that should be followed. Certain components should be replaced in pairs. Wearable parts like Calipers, Shocks, Bearings, Tires, to name a few. While you could get away with doing one side it isn't good practice. At 100K+ your bearings are not failing because of a defect. They are failing because they have reached their service limit. One side failing means that the other is on barrowed time. If you plan on keeping your vehicle for another 100K, it makes sense to do both at the same time. If you plan on trading yours in a few months, it may be worth rolling the dice. Have you ever seen the results of a failed wheel bearing?
I will agree with you on this point, and may draw some flack from others. I do recommend in a lot of situations that you replace certain things in pairs. I do however understand that some people do prefer to consider hub bearing assemblies as individual swap items.
Another vote here for the pre-assembled hub/bearing. That way it's a simple r&r affair. I went with the Bluepit's with the Koyo upgrade. Didn't know there was a vendor on the forum that sold them...or I would have supported them.
I too agree about doing both sides at once. It just makes sense. The bearing is normally trash due to wear/age. Since both bearings were installed at the same time, it makes sense that since one is bad, the other cannot be far behind.
No worries, BluePit does put out a good product. I just put out the same product, but cheaper. ALL of my assemblies as of this past week will have the Koyo bearings. Not as an upgrade, but as the primary bearing. Mine are a lot less than his Koyo set.
This job is a COMPLETE PITA!!! I have done this and after hours and hours I went ahead and bought the preassembled hub/bearing combo and the job was easy after that.
I woud buy the setup from bumper2bumper auto in a heartbeat! Thats the absolute best deal I have seen and almost half of what my assembled units cost.
Good luck!
Thank you for your kind words! Let everyone know about me and I would greatly appreciate it.
Um, before you go saying ANYTHING about what I do, or buy, you better check your facts. Stop making statements about me of which you have no basis in fact.
To take a look at what it takes to build these, go ahead. If you look at Rock auto right now, as I am, the average purchaser like you and the others on this forum can buy the Bearing that I use for $70, and the hub for $41. Then the seal for about $10. That adds up to $120. That doesn't even include shipping, which is, for those 3 items, about $16. So now you have bought just 3 new items, for a total cost to your door of $126. (By the way, I also include the o-ring seal in the back, and 4 new installation bolts, but let's not split hairs here) Now if, like you have suggested, you could take those components down and get them pressed in for $15. You now have $141 invested, NOT counting your time to get to the shop, or the gas to get there and back. So you have now saved $43 each unit. Again this is NOT including your gas or time to go get it pressed in. By the way, that place that presses in your bearing, are they giving you a 12 month, 12k mile warranty on their work? Did you check on the details of the warranty from RockAuto? Hmmm...
Still not seeing your savings of $200 per side. Especially considering the o-ring and new bolts are not included. If someone were to reuse their own bolts and o-ring, and buy just the components and take them down to get them pressed, it would cost about $141 each. Two sides would be $282. Buy a pair from me for $368, means a difference of $86 total, not $200. Again, if you get my assemblies you don't have to take anything to a shop and wait. Total time spent would be the 5 minutes it takes to order them, and about 1.5 hours to replace a pair of them (This is the average time my customers have said it takes them)
Like I have said before, they are paying for convenience as well. To them the $86 is a cost they are willing to give to save the headache of having to scrounge up the parts, drive to a shop, wait on them, drive back home, and THEN install. With mine you open the box, remove your old hubs, install mine, and drive on, with a warranty.
I have seen plenty of hubs have problems as well. I completely agree with BWI.
What kind of warranty do you offer for your product? :horn:
Let's be accurate on pricing. I am looking at Rockauto right now and to have the bearings, seal, hub shipped is $117. $10.37 for 4 bolts and an o-ring. $10 labor to press them. That is a total of 137.37 which will put $52 in my pocket that I wouldn't have by ordering them from you. Yes I would have to order the parts, but I have to order them from you. I would have to stop by the dealer, but let's be realistic here, I wouldn't need to make a special trip and would combine it with other trips.
That means I would save $104 doing both sides with the same parts you are supplying. I arrive at the $200 savings by not replacing the hub and bolts if they are serviceable. Again, not saying there is a right answer here, but these are the options if you want to save real money.
For what you are offering, I think the price is very good. With very slim margins, I really don't see how it is worth your time. Once you add in your time to source and procure the parts plus your labor, and add in free shipping, which we all know isn't free to you, I don't see how it is even worth your time. I doubt anyone who orders your parts realizes how little you are making.
noob question: so the house recommends changing both hubs/bearing at the same time....instead of just changing out the bad side?
12 months, or 12k miles.
Edit: I would like to see what parts you are looking at for $117 shipped, and the bolts and seal. Care to specify in case someone else would like to find that deal?
I make a fair enough profit on them. You have to realize that I do not pay what you pay for parts on Rock auto, or any of my other suppliers. As a business I get a wholesale discount when you consider that I order 20 or more bearings and hubs at a time, so it allows me to make an acceptable profit on them, even after shipping. I am not about cashing in on big bucks like the ones you find on fleabay. I started this off on Tacomaworld helping out my friends. As for my time, I build them two times a day: First thing in the morning before my shop opens, and then in the evening when my shop closes.
That is a toss up there. I would say we are a 50/50 split on them. My thought process is that if you are always on the road, never 4 wheeling, and never driving through water/mud deeper than 6 inches, then you might be just fine with replacing one. I have had several single-hub orders. However if you wheel a lot, get off-road and in mud and deeper water crossings and such, you might be best off replacing them in a pair. Maybe keep the good older one as an emergency backup as some of my customers have done.
MOOG/NATIONAL Part # 515040
Front
$64.79 $64.79 Remove Part
Click to Jump to This Part Listing in the Part CatalogBrake/Wheel Hub : HubRelated Parts
DORMAN Part # 930403 {#4350260180, 4350260201} Generation 1 (Only 4 Remaining)
Front; 4WD
$41.79 $41.79 Remove Part
Click to Jump to This Part Listing in the Part CatalogBrake/Wheel Hub : Wheel SealRelated Parts
TIMKEN Part # 710477 3.221 in. Shaft Size; 3.807 in. Bore; 3.813 in. Outer Diam; 0.750 in. Width
Front Outer; 4WD
Front; RWD
$1.69 $1.69 Remove Part
Subtotal $108.27
Postal Code:
Shipping: Ground (2 to 6 business days) - $8.753 Business Day Express - $18.932 Business Day Express - $19.88Next Business Day Express - $36.74 $8.75
Total $117.02
There you go. The bolts and o-ring price are dealer price. I actually found the bolts and o-ring at Napa for a little over $6, but for the previous pricing I was matching to what you offer.
If you have the money, and plan on keeping your vehicle forever, do them both at the same time. They are wearable parts and both have been subject to the exact same conditions throughout the life of your vehicle. Unless you have one that has failed prematurely due to defect or abuse you are on barrowed time with the other.
[MENTION=99491]Bumper2Bumper Auto[/MENTION], Do you ever take requests from customers to have their bad hubs rebuilt and sent back to them? or would you do that? e.g. I order 2 hubs from you and I would like my current hubs remanfu for later use or do you take the olds ones for core charge? Thanks
Front
Front; 4WD
Front Outer; 4WD
Front; RWD
Subtotal $108.27
Postal Code:
Total $117.02
OK,just wanted to be sure. As I mentioned, I am going towards exclusive Koyo brand bearings now, so I wanted to be sure you were quoting the exact ones I have. Thought there is not a whole lot of difference in price usually. I still emphasize that not everyone wants to order all the parts, then take the hubs to a shop to get them all put together. Also, as mentioned, I offer a warranty on my assemblies. Even at your prices of
$117.02 and $6 for the bolts and seal, you are looking at saving $60.98 over my completely assembled units. AND you still have to take them to a shop and get them pressed together. The average cost most people say around here is usually about $20 or so. So now their savings has dwindled down to $40.98, not counting their time or gas to get to a shop. Feel free to make them all you want for yourself, but you shouldn't slam other people for wanting to buy them pre-made, or try to make someone who does make them look like they are not worth it. I believe I mentioned it once before in that you can easily drive and extra 2 miles to buy a 6-pack of beer at the grocery store for $2.00 less than at the corner store. But people willingly pay that extra $2.00 per 6-pack for the CONVENIENCE of not having to do anything more than hit the corner store. Same thing applies here: People are willing to pay the additional cost of $41 to just have the entire assembly shipped to their door, ready to install.
I have not offered that before because when you take into account shipping charges, it is not always worth it. You have to ship the hubs to me, pay return shipping, then cost of bearing and seals, etc. Also if your wheel hub is damaged, then you just wasted all of your time there, because then I would need to replace everything. It is a crap shoot there since we have no idea the condition of the hubs.
I do not know if I have mentioned it in this forum or not, but the reason so many of the hubs do get damaged is because when the bearing begins to fail, it allows the wheel hub to spin off-center, resulting in pressing the hub against the metal part of the seal, and quickly scoring the hub.
We are not talking $2 more on a 6-pack. I don't know anyone who would walk away from $40. People are free to spend their money on whatever they want. I was merely showing that there is a cheaper way. The math is the math. I really don't see how it could be worth your time for the $10-15 per unit you net on the deal, but that is great for anyone that wants to take advantage of it.
Well then you should talk to my customers. I have sold over 150 of these units over the past 2 months alone. They are quite happy with my products. What I find funny is how I reiterate things so much, and you STILL ignore it. I am not making only a $10-$15 profit on each unit. I buy my parts for a lot cheaper than you, or anyone else can because I buy wholesale, in large quantities. I am quite happy to make my profit and see my customers happy. You have to realize that I am not just some guy who decided to just start making these units. I own a 9600 sq ft service and repair facility and turn out several thousand dollars a month in gross profit. I make several different products for several different vehicles.
At this point I think I am beating a dead horse with you. I will let my sales and products speak for themselves.:deadhorse:
utkrstam
