Singtoe
High price of Gasoline, benefits of propane - The conversion looks promising.
Pros -
Gasoline is >$4.00 per gallon propane is ~$2.75
Octane rating is around 100
Cleaner combustion so Engine oil will last longer (Thus the engine will last longer)
Conversion lets you switch between LPG and Gasoline at a push of a button.
Cons -
The conversion is a little bit pricey ~$1,000.00 (kit , tank, lines, spark plugs)
The engine runs a little bit hotter so colder spark plugs will need to be installed.
The BTU of Propane is about 10% less then gasoline so there will be some power loss of power.
You will need an propane tank installed inside and there will be loss of cargo space.
Anyway, I am seriously considering the conversion. I have a buddy overseas who can send me LPG sequential injection system that piggy backs over the the OEM Toyota fuel injection system. The only real modifications is to drill the intake manifold for 6 propane inlets. Everything else is plug and play. The LPG system uses the oem Throttle body and oxygen sensors for the perfect fuel map every time.
Here is a picture with a basic system.
This system is for a 4 cylinder and apparently does not use the lambada control.
Here is a link to propane conversion - TTORA Forum that has a conversion done onto a v6 tacoma.
Here is his picture of it installed on a 5vz-fe
If there is any interest, I will see if i can get several shipped from overseas. The ones that are sold over here are way too expensive and not fully featured as what i can get.
Figure the price of the kit to be around ~$700. This would not include the propane tank or hoses but will have everything else.
Pros -
Cons -
