Anyone from Riverside, CA?
crespoh69
Member
Hey guys, just moved over here and it's a great area, really loving it! Only real issue is the freeways though and my 99 4runner. I absolutely cannot drive it on the 2 lanes to the right of the carpool without it shaking like crazy. Has anyone in this area experienced this as well? Anything you may have done to resolve the issue? Granted, I still have the original from the factory shocks and only have a stiffer front anti-sway bar but feel it shouldn't be this difficult to drive, it honestly feels like I'm going off-road a bit. Once I get closer to my job though, things are fine.
If the shocks are original, they are dead. If you have a friend ride alongside you on those rough freeway zones, your friend will probably see the wheels rapidly bouncing up and down.
Probably much more has gone south suspension wise. Start inspecting bushings of all types up front and rear + LBJs. I replaced all mine in Dec with oem, rides like a dream and handles even better off road too, not cheap yet worth it. Luck.
Check your tie rod ends. As if they have movement you could need to replace them. Also verify your tires are balanced as well as a possibility. :)
seltzernator
