Anyone have light's in lower grill
Falls
Super Moderator
I was polking around there on my 06 and it seems there is a nice steel bar behind the lower grill for mounting add'l light's.
I saw 1 person that had some oval type light's mounted there , just wondering if anyone else has some .
i must admit that this set up is strudy. people call it wimpy but if you tighten the bolts with enough levrage. its pretty freaking strong. i had my father, all 250 lbs of him sit on it, and no issues at all.
4th option
This is probably the most difficult of all the options. I did a modified version of Momo's floating lights. Then added a brush guard to help prevent damage from taps/bumps. I've been very please with the results. Since these photos I have added PIAA locks for some security and to cover-up the connector bolt below the lights.
lights4.jpg~original
IMG_0400.jpg~original
I can't find the thread, but there's a member here who cut out his lower grille for rectangular PIAAs. The PIAAs were a driving and fog combination lamp, with a projector for one of them.
I mounted some Eurolite driving lights behind the lower grill and used the mounting plate that came on the lights and simply screwed one self-tapping screw into the frame crossbar. Easy and dont have to get other mounting brackets or bull bars. Gotta be careful of melting your grill though. Ill post picks if i can find them when i get home.
Re: 4th option
That looks really sharp. I like it a lot. Wish id a got a black 4r
ironadrenaline said:
i can get some universal mounts from a jeep and mount two more lamps that i have just sitting around.
Can you point me in the right direction for these universal mounts? I've been searching everything I can think of for some kind of 2" tube clamp to mount an extra set to a safari bar.
JD
Is that the bar behind the grill in front of the coolers?
If so I used this to mount a set of microthin strobes but they don't really put out much light unless you cut out part of that lower grill area. I took my set off and relocated elsewhere.
