Anyone know the answer?
JoeDuke
SO for this winter I need a place to hold my full size spare, but it doesnt fit in the back because I need to put all the Snowboarding gear and I already have subs back there. So I was wondering if anyone has seen or knows if a Snowboard rack will fit on top of a Yakima Loadwarrior with the spare inside of it. If someone could help me out with this that would be great, or some other clever ideas but i am not building a spare tire rack to put it on the back. And if you have them, pictures would be awesome.
you can do this...i know you said you wouldn't make one, but i thought id share.
PUPandtirecarrier.jpg~original
I just don't like the look of that carrier on the back. I jut want to know if a ski rack will fit on the load warrior over a spare tire.
Exactly where its supposed to go? Underneath the rear like singtoe said.. Otherwise you better tow a separate trailer for the thing because you have exhausted other options.
If the tire is too big to fit it in the stock location, then inside would be your best bet.
http://www.toyota-4runner.org/3rd-gen-t4rs/100913-removable-tire-carrier-3rd-gens.html
Something like that and it should still leave decent room for your gear. As far as the subs, well honestly they aren't as much of a necessity as a spare or warm clothes, but you could always do something custom rather than have a huge box that takes up a ton of your cargo room. Hell with cj80cruiser tire mount you should be able to build a custom box that sits over the wheel well between the plastic and the tire. The right sub should provide plenty of bass from the room offered in that location.
Not sure if this will help since you have subs but if it, or if any part of it will work let me know. I'm changing the mounting bolts over to a ubolt since I can keep from having so much bolt sticking up past the mounting hole.
thats what I think Im gonna end up doing. I will have to only use one sub and get a new box so i have enough room.
EnviroHokie
