Anyone put a "Better Built SUV Drawer" from Northern Tool in their 5th Gen yet?
c350z
Came across this and it looks decent, and seems like it would fit on top of the slide out cargo tray.
Better Built Short SUV Drawer — Aluminum, 37in.W x 26in.D x 10 1/2in.H, Model# 76217119 | Truck Box Storage Drawers| Northern Tool + Equipment
Here it is in an FJ
20140321_Storage_Drawer_1.jpg~original
Anyone here have one in their 5th Gen? Got any pics?
thanks
The problem is with one large drawer, everything is commingled...as in a couple of good bumps you may as well put in a blender
True, but I am sure you can rig up a divider pretty easy.
I just like the idea of the metal system of building one out of wood, and the other options like tuffy and truckvault are just to expensive.
I have one, haven't installed it in the cargo area just yet but there are a few on the site that have it installed. I link to the thread if I can find it again
Sent from my SM-G920T using Tapatalk
No real reason, just been busy and haven't gotten around to drilling the holes to attach the turnbuckles to the box and then have em connected to the d rings in the truck... it's a great drawer and would recommend it
I need more decals also!
Nice decals, we have similar taste, I'm down to one bottle of dillo dust
Is it possible to remove the drawer and drill at four corners and permanently bolt to the bed of the truck? Eliminating the use of turnbuckles?
What I am thinking is removing the rear carpet mat, leaving the floor carpet, drilling and then setting the box, at the four corners, on some sort of Delerin/plastic spacers, bolting through with SS hardware
Cutting the mat removed and use this on top, adhesive to hold in place. Once the drawer is removed, then you can fabricate and install some sort of divider system with moveable inserts, sort of like a Plano plastic tray. Even go as far as Linex inside the drawer, to quiet things down. Or use drawer liner like on my roll around tool boxes.
77
77
Yes the drawer comes out and you can absolutely bolt it to the rear floor if you wanted to go that route...
$500!?!?!? for that?
I use 80/20 stuff for my business, and it's the perfect thing to use for making your own custom fit drawer. https://www.8020.net/
I will post a new thread with the exact things I use and a step by step. There will be some cutting and drilling involved, but since it's aluminum, you can use wood saws to do it.
Not that the one from Northern tool is junk, it's a great plug and play item. I just want a lower profile (2.5" interior height) and the full width of the back.
caspian
caspian
I'm eager to see what you come up with as I'm considering a low profile option as well.
