Anyone rocking Pro Comp Series 7032 rims?
These are the wheels I'm running right now with BFG KO2 265/70r17. My suspension is stock except for a 1 inch Cornfed lift in the front to level it out. They have a wider stance than the stock SR5 wheels and I think they look great. I don't really have any pictures showing how wide the stance is but this one kind of gives you an idea.
I think with 4.75 back space, 9 inch width and -6 offset you have some rubbing. I just went with pro-comp 05s because I could get them with 0 offset, 4.5 backspace (same as stock) and 8 inch width. With 265 wild peaks I don’t have rubbing with stock suspension.
Thanks, not what I wanted to hear tho lol. I found a deal on the 7032s brand new for $350 so trying to make them work. Sounds like a pretty nice price to replace the OEM wheels with some blacks, but don’t want to deal with rubbing.
Well if there is rubbing it’ll probably be an easy fix; Fender liner mod, mud flap removal, or bumper trim. On stock size tire I doubt you’d need to do a body mount chop.
I've only noticed a little rubbing in reverse at full lock. I think you'd be fine without spacers but you might have to adjust the fender liners. $350 for the set is a steal!
I hope to pull the trigger on them tomorrow! After some research, I’ve read that tires are tougher to find for 9 inch wheels, was that your experience? And do you know if the stock SR5 tires will fit them in the meantime?
I checked with my tire guy and gave him the wheel specs before pulling the trigger and he said that mounting the stock tire size on 17x9 wheels would be fine. I had seen lots of other people saying the same thing online but it's best to hear it from whoever will be installing the tires.
AndiGarage
