Anyone running aftermarket rear bumper without body lift?
I just got new Energy Suspension body mount bushings and they've reduced the body/frame flex incredibly. My CBI was rubbing a bit and same with the shrockworks up front. No more rubbing.
So do you think that the rear bushings in this set are stiff enough to
prevent the rear bumper / body interference ?
Max
Bar none, these bushings are WAY stiffer than the stock ones. The compression you get from the rubber ones is practically non-existent with the polyurethane mounts. The result is definitely a firmer/more solid mounting. Check out how mushroomed the old rubber was, and note that the polyurethane bushings are even an upgrade compared to brand new rubber.
Take a look at them side by side...
Yeah I 2nd Max's attempt to quote you above ^^ lol. Do you think the steel mounts are sufficient?
also, you got any resources on the HOW of this project? I keep digging and can't find shit in the forum. (Watch someone find something super obvious :laser::wave:) Scale 1-10 how hard was replacing everything?Mega tools required or basics sufficient?
It's completely doable with a basic toolset, a decent floor jack, and some 2ft sections of 2x4. My rig has a 1" body lift, which helped with extra spacing, but the install procedure was identical. It really depends on your mechanical skill, but it's about a 4 on the scale for me, an oil change being a 1, and a strut install being 5.
How's the ride quality on and off road with the new mounts? I have a pet theory on it, but want to hear actual experiences!
-Charlie
When you say "a couple flat washers" is that for each bolt or just 1 washer per bolt?
yes 1 washer per bolt worked well. basically by adding a washer I dropped the bumper by maybe 1/8" and that was enough to stop it from hitting the pinch welds during flexy time.
by the way, I would say the largest improvement in ride quality was a result of replacing all the body mounts. really made things smooth out again.
