Anyone running Fifteen52 Analog HD wheels?
FLYNAVY53
Member
Just picked up a stock 2002 4runner. It has the factory 16x7 wheels and 265/70/16 tires. From what I can tell, those wheels had a 15mm offset.
I'm considering going with the Fifteen52 Analog HD wheels which are 16x7.5 with a 0mm offset and some 265/75/16 tires.
Based on the size calculator, the new setup would be the same width, 26mm larger diameter, and 21mm further away from the mounting surface.
I THINK these will fit, but would love any input, and pics if anyone has them.
Thanks!!
As far as I’m aware it will fit just fine. There’s something to be said about lug-centric vs hub-centric wheels balancing differently or something but I haven’t heard of that size tire not fitting.
cool, thanks. I assume they'll fit without issue but even if there is some slight rubbing I'm probably going to lift it slightly with the Tundra/OME springs and Bilsteins as I'm pretty certain it still has the original springs/shocks on it.
It would definitely fit then, I also have a mild lift and am running the same size tires and have no issues rubbing.
BillM777
