Anyone running Hub Centric Rings?
Yoter
First of all I am really sorry to bing up such a played out subject.
I did a few hours of searching and havent found any information from people who have used Hub Centric rings.
I have some after market rims with what I believe is a 108mm center bore (need a more accurate way to measure) and from my research I need to purchase hub centric rings in order to avoid balancing/wobble issues.
I would like to know the following:
If I buy hub centric rings will the wheels mount/perform essentially as well as OEM?
Has anyone had any issues with hub centric rings?
Can anyone recommend a specific brand/ type?
Any info is greatly appreciated, debating if I should buy tires for these rims or hold out for some tundra TRD's. Wish I had researched the issues with Lug centric mounting prior to purchasing these wheels but you live and learn I guess.
Never needed or used them on the 4Runner, but they worked quite well on my MR2 and old IS300. They made enough of a difference on the IS that I even noticed when a tire shop left a rear one on the spare instead of transferring it to the new wheel. As far as brand its a pretty tough item to mess up, I'm sure just about anyone that sells them will work okay.
Southshore
