Anyone think the frame recall is going to go through?
Is this a DIY product? Doesn't seem like it would be a lot of fun crawling underneath and spraying this stuff all over, including on me and the garage floor. And how would it get into the frame if it doesn't have access points to spray into?
I did spray FluidFilm on the 2008 after I flushed the interior of the frame rails. Probably wasn't necessary but it was on jackstands installing the new suspension, so I did it. Spray cans, sprayed it into all of the openings I could find on the rails. It's a waxy product, lasts maybe a year on exposed surfaces. The product has great reviews.
Your daughter's 2006 will be fine without such treatments. Frames don't rust out in CO, I've had Tacomas, a Tundra, notorious rusters in Eastern humid climates, no problems here.
Do they use salt in Colorado, Denver specifically? My daughter is going to move there after graduation with a pristine, Houston all its life, 2006 4Runner sport. We both hope/plan for this to be her daily driver for another 10 years. Wondering if we should be concerned or take some preventive action...
We moved from CA to MN for almost five yrs with a 2008 in 2010. That part of the country uses salt religiously and it’s on the ground intermittently 6-8 months out of the year. Knowing we’d eventually be moving back to CA I was super concerned about rust and did a ton of research on options, including undercoating, ultimately deciding on regular car washes because the undercoating processes can miss areas, certainly including inside surfaces of the box frame.
Did a bunch of research on good full-service car washes in the area (undercarriage wash was a must), picked one not super close to home but with stellar reviews, bought an unlimited-visit monthly membership and went at least once weekly during winter months. We moved back to CA 5 yrs later almost entirely unscathed.
Just my experience moving from no-worry to high-worry rust environments.
It's a long shot, but I'd happily take a fat buyback towards a new Toyota truck.
https://www.forbes.com/sites/jensen...cks-have-dangerous-rusty-frames/#685131aa7302
Dec 18, 2018, 10:40am
New Class Action Claims More Toyota Trucks Have Dangerous, Rusty Frames
Gary Weinreich says the frame of his 2005 4Runner was so badly rusted a steering component broke away while he was traveling down a two-lane road.GARY WEINREICH
By Christopher Jensen
A federal class-action suit claiming that the frames on the 2005 – 11 4Runners are defective and dangerous because they rust prematurely has been filed against Toyota. The action echoes a class-action settled last year but covering different Toyota trucks.
The allegation in the new class-action contends the frames “are prone to excessive, premature rust corrosion because the frames were not properly prepared and treated against rust corrosion when they were manufactured."
It names Gary Weinreich, the owner of a 2005 4Runner, as the lead plaintiff in the suit filed in South Carolina.
“The excessive rust corrosion on the Toyota 4Runner compromises the vehicles’ safety, stability, and crash-worthiness because important suspension components, engine mounts, transmission mounts, and body mounts anchor to the vehicles’ frames. It has also affected the value of the vehicle,” according to the suit.
In an email Toyota spokesman Eric Booth said “the safety of our customers is a top priority. While we cannot comment on these specific claims at this time, we will respond in the appropriate forum.”
The class-action settled last year covered 2005 – 10 Tacoma models; 2007 – 08 Tundras and 2005 – 08 Sequoias. (continues) ...
Like [MENTION=142445]flipflopnfly[/MENTION] says it's the magnesium chloride that is the killer of all things metal. It is mostly applied as a liquid, some call it brine, but it will eat through painted and primed metal. It turns semi truck trailers to scrap metal in a few years.
Even here in Oklahoma where we don't get much winter, cities have started "pre-treating" the bridges if winter weather is forecast. I think governments are being sold this "new" form of road deicing by some very unscrupulousness business people.
Don't just take my word on this, read up about magnesium chloride and metal. Talk to an automotive or other equipment manufactures. We need to petition to stop using the stuff on our roads.
you are 100% correct. The chemicals being used are politically motivated business practice. They need to go back to sand! The rate at which these chemicals cause corrosion of vehicles and roads which together compound the problems 10 fold. Not to mention, the most likely long term effects on the environment and our health. Seriously need to start a petition.
You're 100% on point. Even worse than the MC is the brine IMO. Horrible stuff. Petitions do not do jack shit though. The people signing it will be a minority. Most people go through a car every ten years MAX, not enough time to understand the effects of these chemicals for some average joe shmoe.
Dang, I have a 2007. It'd be nice to get the frame taken care of. I got the rust ground off it and an undercoating put on it so hopefully that will alleviate most of the potential rust problems.
Unfortunately, even though the exterior may look good, a lot of the corrosion problems we have originate from the inside of the frame where it’s very difficult, or impossible to clean/coat correctly. I do agree though, that something done is better than nothing. I sandblasted, primed and painted my frame, but I’m still very worried about what’s happening on the inside where I couldn’t get to.
You'll see a tanker truck spraying scalding hot water/mag chloride brine before every blizzard here. It's nicely aerosolized so at highway speed it gets inhaled into every nook and cranny of your vehicle, especially if you pass the truck and get a "broadside" from the sprayers.
Go to an underbody car wash as much as possible in the winter, if you let that shit sit caked on your truck for a week it'll start to cause mischief.
And the truck in the story looks like it spends its weekends in half a foot of saltwater at a boat launch... never trust anyone named "Gary."
Mag chloride and gravel.
You get the salt spray and shotgun gravel blasts.
With the hail in the summers Colorado is a very hostile place for cars. Her "pristine" 4runner will look like hell in a year.
Plus if she wants to do the "trendy" downtown things in Denver, everyone there is from the Bay Area and parks like it's a contact sport, especially when it comes to parallel parking.
Anyone hear any updates on this frame recall was googling around and there's still not much said other then some guys are doing some kind of law suit which prob wont go anywhere, investigation is still open on NHTSA website...
just found some holes in mine. president moron isnt helping by shutting the government down, vacant, interim or incompetent officials
Jhunt
