Anyone Using Extreme LED X6S Slim Series Behind Grille?
jagsr71
I'm looked all over and I've found plenty of applications for light bars that are 30"-32" behind the grille.
The most popular brackets are Rago and Caliraised.
Is there anyone using the 25" Extreme LED X6S Slim Series behind the grille? If so, what bracket are you using?
I have the Rago Fabrication Universal bumper bracket with the mounting plate and you can easily run that light bar. It is extremely universal so you won't have any issues with size. I do think you would have to get that mounting plate in order to run that short of a bar though. I think the shortest bar I've seen work was 28" end to end.
I have the X6 32” mounted on the Rago Fabrication universal brackets. No issues. It’s a pretty snug fit but it works. I think you’ll need the mounting plate to go along with the brackets if you’re running the shorter width light bar.
Okay good to know. The only application I've seen this 25" light bar being used is in conjunction w/ C4Fab low pro bumper. I was curious to see if anyone had actually placed it behind the grille itself.
Thank you gents.
