Anyone using Soronan's Rear Sway Bar Bracket?
Man I've no idea how I missed all of these replies... So I've got the brackets and I need to order links. Ordering stock rear links so we will see how well they work with the lift my 890's give.
isnt it recommended that you run a different link if your lifted more than 2 inches and use those brackets. I can say I did NOT when I did a ss lift with those brackets....i only lifted 2 inches.... but....just saying/asking
PHP:
I don't think anyone knows, or very few people. Once all my parts arrive and I have time to install it all I'll post some photos
From their website:
"You MUST use stock length rear 3rd gen 4Runner end links. Those are actually a bit too long already so your longer than stock links are not going to work."
"We have ONLY tested this part with the front coils from an FJ80 Land Cruiser. I have no clue if it will work with other coils. We have not tried it with anything else."
I interpret that to mean that you need about 3-4 inches of lift in the rear and stock links for the geometry to be good.
The brackets and stock rear links are designed around a 3-4 inch lift in the rear.
that is cheap.....how long have you been running them....like hold up and life
I put some NAPA ones on last fall, and am surprised how the rubber is cracking on bushings already
Been there about a year, holding up just fine, other than some light rust you see at the top of the threaded portion. Nothing that some paint won't fix.
PRWhite
