Anytime Backup Camera and Front Camera - February 2017 Group Buy
bjohnston115
Hello All! Thank you for making the previous Group Buy such a success! As promised I am creating a group buy for the Front Camera (or more than Front Camera) Kit and also adding the rear camera override kit to this again.
Signups will be made at the link below and all instructions are on the site
Antyime Backup Camera | View your Backup Camera at any time!
This kit is designed for 2014+ trucks. There is an option for earlier models but involves some modification (no cutting of wires) to the factory harness.
If you have any questions please reach out here!
Lets start this off...
If anyone could post this on Tacoma World or the Tundra forums that would be great.
Thanks!
Thanks!
I'm in for the front camera. I just bought the rear camera override.
Thx!
Sent from my Pixel XL using Tapatalk
I signed up for the additional camera kit. Will you have an option to buy the actual camera?
Sent from my LGLS992 using Tapatalk
In for both! :)
I have a 2013, what are the additional requirements?
Pre 2014 is not a direct plug in harness. You will need to remove two wires from the factory harness and replace them with the wires I supply. Some people chose to just cut the wire and other choose to remove it from the harness. Either way the choice is yours. Cutting is not required.
Any input on the easiest way to get power to the front camera? When will this go live? Thanks, Kags
The key is to get a switched 12v source and i was not able to find one under the hood. You can run a wire from inside the cab when you run the video feed for it.
Or if you have an auxiliary fuse box under the hood with switched feeds you can use that.
Buying will probably be live within two weeks and shipping will start ASAP. I do my best to ship immediately and items usually arrive within 4 day of purchasing.
I tapped into the cab fuse box (sorry cant remember which one, obviously pole is important to keep it fused) and ran a control 16ga wire to a Bussmann fused and relayed power block (Bussmann 37702-2AA0022). This gives you ignition switched power 12v @ 70amps and a fused always hot pole for anything you need under the hood.
mek
