Hi,
I just installed an ARB rear locker on my 03 4R. The bench test worked fine. The wiring has been checked three times, everything seems to be fine. The compressor works fine and engages everytime you activate its switch but when you hit the rear locker switch nothing happens. I do not have a front locker. I have searched for air leaks between the compressor and axle and have found none. I have also found no wiring issues. Right now the "ignition" ARB wire is hooked to a 12V swiched wire coming off of the 12V outlet in the console, left of the gear shifter. The "dash illumination" is coming off of a 12V wire that controls the lighting of the 12V outlet located left of the shifter. I welcome any help anyone can offer.
Thanks,
Chris
Thanks,
Chris
