ARB Fridge Freezers! GB now thru 8/15. Massive Discount + Free Digital Temp Monitor
One of our most requested items is the ARB Fridge Freezer!! Since its summer we decided it was a good time to put these on sale to help keep things cool.
GB Details
Now thru Aug 15th, 2015 save big on all ARB Fridge Freezers & Accessories
Free Shipping to lower 48 states
FOLLOW LINKS BELOW - USE CODE T4R TO GET DISCOUNT
[/URL]
ARB Fridge Freezers are the ideal way to keep your food and beverages chilled or frozen on your 4x4 adventures, regardless of ambient conditions. Not to be confused with less effective 12 volt ‘coolers’, the ARB unit is a true refrigerator/freezer. Own one and you’ll never again find your lunch water- logged by shifting ice, and there’ll always be a cold drink on hand during the sweltering summer months.
Two separate power cords are included, one for AC operation (120 volt) at home, and one for DC operation (12/24 volt) in your vehicle. All sized models are able to maintain sub-freezing temperatures in 90° F heat, while only drawing 0.87 amps per hour (50QT model) from a 12 volt power source.
  • 100% CFC free
  • Low amp draw
  • Ice free operation
  • Three year warranty
  • Powder coated zinc steel cabinet shell. Zinc steel provides excellent corrosion resistance
  • Recessed powdered coated steel fixed carry handles
  • Two piece injection molded lid, UV stable
  • Convenient on/off power indicator
  • Integrated battery protection system (12/24V DC)
  • Solar panel & generator compatible
  • Deep storage capacity for large upright bottles
  • User friendly, forward facing thermostat control
  • Built-in 12, 24 and 120 volt facility, making it ideal for use as a second fridge
  • Rounded corners & edges to protect vehicle upholstery
  • Fully removable lid & basket for easy access & cleaning
  • Ventilation grills allow operation even in the most confined cargo areas
  • User friendly, right angled plug-in point from cord to fridge
  • Operates at extreme angles (up to 30°) without affecting operation or reliability
TECHNICAL
  • Recessed front mounted digital control panel
  • Internal LED cabinet light
  • Separate dairy/fruit compartment
  • Interior drain plug
  • Unique stainless steel detent hinge with quick release mechanism
  • Integrated power system - No external power transformers required to operate the fridge on 12V DC, 24V DC or 110V AC
4 Sizes Available:
37qt - ARB 10800352
50qt - ARB 10800472
63qt - ARB 10800602
82qt - ARB 10800782
ARB Fridge Accessories
An optional transit bag is available to aid with insulation and protect your fridge from inevitable scrapes and dents.
ARB's tie down system is ideal for ensuring that your fridge is secured at all times. Tailored to suit the ARB Fridge Freeze, this tie down system uses powdercoated clamps and any easy quick release system.
Suitable for a range of fridges, the ARB fridge slide ensures easy access to your fridge and features a multi-position latch and a lock-in lock-out mechanism to ensure that your slide stays in position no matter what position your vehicle is in.
Click here to view entire ARB Fridge Freezer Line
Use code T4R to get instant GB discount!​
GB Details
All fridge orders qualify for free digital temperature monitor
FOLLOW LINKS BELOW - USE CODE T4RGB TO GET DISCOUNT
http://shop.totalautomotiveperformance.net/arb-usa/arb-fridge-freezers/g-78829.aspx
  • 100% CFC free
  • Low amp draw
TECHNICAL
4 Sizes Available:
37qt - ARB 10800352
50qt - ARB 10800472
63qt - ARB 10800602
82qt - ARB 10800782
Use code T4RGB to get instant GB discount!​
Awesome news. I'm in
Too bad no shipping to Canada...
We can ship to Canada no problem, but it wouldnt be covered under the standard free shipping. Even tho you would pay freight, the price should still be under what you would normally pay for one. Shoot us your postal code and we can quote you a few options. Thanks!
Makes it so tempting as I have been eyeing these for about a year now!
Hopefully you have another one around Christmas. . . .
Has ARB found a solution on how to mount the transit bag with the adhesive strips? I slid the transit bag over my fridge and within about a week the adhesive strips started peeling off. I contacted ARB and they pretty much said too bad. They didn't offer an alternate solution or a replacement adhesive kit.
They should offer the replacement kit with no problems, let us know if we can provide a contact for you.
Thinking about getting one. Do we need to add controller to cart or is it automatically included with promo code?
