ARB3423020 Front Bumper Devils Advocate
Son-Uva-Driller
Well its high time I get myself a front bumper. I've been doing lots of reading and there are several mass produced models that I really like. I've even considered having one custom built.
Of the mass produced models, I leaning towards the ARB 3423020. On the verge of pulling the trigger on this but before I do, I was hoping I could get a few members to chime in with some of their experiences good and bad regarding this bumper.
I bought mine used. I like it and even think the new price is a good value. It comes powder coated so that is a plus. The weight is very good for a plate bumper. They really put some thought into if it got into a crash . Now I know ARB has more money to do test crashes with their bumpers but the mount itself is an actual impact absorber. Don't know of any aftermarket bumper that has this. Only Con I can think of is the design style wise is a little old and some members like the newer bumpers styles better.
Some consider the impact absorbers a con, but to each his own.
A con that I can think of is that unless you're able to weld, it's not a cheap bumper to have installed on a 4Runner, as the frame ends should be modified in order to safely utilize the bumper.
A friend of mine is currently calling around to some shops in the area and was quoted $500-$600 for bumper and winch install. I am sure this is a high price, as to me that's completely unacceptable.
Perhaps some folks with the ARB can comment on cost of modifying the frame ends (or about how long it took them) to get a better idea of what the "standard" should be.
Just curious to why some would consider the absorbers a con?
Some people like the rigidity of having a solid bumper that is not necessarily DOT approved for air bags (strictly tacoma experience). This protects them in off-road purposes of hitting something and keeping your face from getting blown off. Non-absorbing bumpers can be reinforced to handle larger impacts with minimal deflection.
Actually the 'crumple zones' are there to prevent the airbags from going off in minor collisions. Since the ARB is much more solid than the tin factory bumper (which absorbs the shock from minor collisions by crumpling) the crumple zones are used. Bumpers that don't have them would be more likely to 'blow your face off' while off-roading since they would transfer the impact energy directly to the frame, triggering the airbag sensors prematurely (like bumping that tree).
The only real modifications you have to do to mount an ARB is cut off the frame ends and drill 2 new holes (one on each side). Welding a plate over the end adds some more support, but the ARB is attached with 6 bolts to the frame, and comes with spacers to keep the frame ends from collapsing as the bolts are tightened.
It weighs about the same as other plate bumpers (probably less than some) - about 70 lbs. I like the fact that ARB has made thousands of these, so they have enough experience to know how to make a strong, lightweight, and safe bumper economically. They are also required to pass gov safety tests in Oz. The fit and finish is very good, and the powder coating is VERY tough (much better than what I had done on my back bumper by a local shop). I would not hesitate to buy another one.
from ARB website, "With an air bag equipped 4x4 it is essential that the vehicle's crush rate and air bag triggering is not altered when a bull bar is installed. To ensure compatibility, ARB assesses each vehicle's frontal crush characteristics and replicates the crush rate into the design of each air bag compatible bull bar and its mounting system. This method enables engineers to achieve maximum possible vehicle and passenger protection without affecting the crash pulse. ARB has invested heavily in vehicle crash barrier tests to validate the performance and compliance of its air bag compatible bull bars, and as a consequence, our bars offer a far greater level of protection than most standard brush guards and grille guards". that tells me that they are still going to go off as in a normal crash. I know they are definitely sturdier then factory tin bumpers but are still designed to deploy the bags. The ARB bumper is a great all purpose upgrade.
Yes, that's what I said, though in less technical (or marketing) terms. The crush zones make sure the airbags go off when they are supposed to (like with the original bumper) but don't go off when they are not supposed to (with less than the Toyota-designed impact) as is possible with a rigid bumper.
my understanding of the energy absorbing mounts is that this was a requirement by ARB to satisfy the Australian equivalent of DOT as it relates to airbag deployment. by absorbing impact energy (similar to a stock bumper) this preserves the factory intended deployment timing of the airbags, where an impact without said zones could result in premature deployment of the airbags. (one of the main reasons i chose ARB)
So a solid mounted bumper (all others) may be stronger and take a harder hit, but would not avoid or eliminate the deployment of airbags, if anything it would cause that to happen sooner than if you were stock.
its been years since i researched all this so take it with a grain of salt, your mileage may vary, yada yada yada.
regarding the frame modification, my take is this. It is advisable to do it, BUT if you do not plan to do any winching i think you'd be fine without it. I as well as a few others i know ran for years without the endcaps with no ill effects. that said, none of us were ever doing any winching.
I had read some time back on a tacoma forum that virtually all tacos who were doing any kind of regular or heavy winching were seeing deformation in the stock endcaps that the tacomas have. To install the ARB on a 4runner you have to cut the factory endcaps off for fitment so its actually a less solid install relative to a tacoma since you do not have that long bolt going horizontally into the end of the frame.
As for the mod itself, its pretty simple, it involves cutting a piece of angle to size, cutting a hole in it, tacking a nut to the back side and welding it in place. Several yrs after initially installing my ARB, I was lucky enough to have a friend do the welding for me. I wanna say that fabing the caps and welding them up took about an hour, maybe 2 tops.
If you are looking to pay a shop for the mod, i would count on removing and reinstalling the bumper yourself (or with the help of friend if you are installing a winch) Id prol wanna pick up the angle, nuts and bolts myself as well to ensure proper grading (grade 8/10.2) and so you are paying for labor only.
While the ARB does look a little bit dated to some, I love the way it looks and i have been very happy with it. It has saved me from some pretty serious front end damage on several occasion, and if i had to do it all over again, i may very well go with the ARB again.
Its been years since Ive researched this so ymmv, also i recall finding a lot more info about this on the tacoma forums.
here is a pic of my completed endcap mod
Good luck!
Edit: I googled tacoma endcap deformation and found this pic. As i recall, the "endcap" mod was actually invented (by necessity) on the tacoma side and eventually migrated over to 4runners for obvious reasons. Here is a great writeup on the mod: http://www.nwtoys.com/content/123-frame-endcap-modification.html
Thank you for all the great input. I too really like the design of the ARB and thinks it looks awesome and will function awesome on my 3rd gen. Another big selling point for me is their availability. No need to wait 4 months + as with other aftermarket bumpers. And then there's the cost, living in Canada there are not many options. Free shipping is great for those who live in the lower 48 but up here we get hammered with the exchange, duty, taxes and shipping. BAM!!!
I'll source an ARB locally and then get the shop that did my sliders to do the frame end caps and I'll do the winch and bumper install myself.
Anyways, off to work now for 4 weeks, no Internet so there'll be no updates on my build.
Hilux 167 snorkel and possibly and ARB bumper install to be done when I get back.
Thanks again.
Ambrose67
