Are limited and sport flares almost the same except for?
hawkcharmer
Member
I'm wondering if the limited and sport flares are almost the same except for a few pieces. I know the part where the flares go to rear/front door running board area are different, due to the cladding. but is the top section above rear wheel below fuel door the same and are the rear mud flaps and front bumper piece the same?
The reason I'm asking is because I have an option to purchase inexpensive limited flares, but don't want the door cladding that the limited flares have.
The sports seem to have one continuous flare that tapers off nice towards bottom of doors in front, so I know I would need to purchase those.
And also the piece that tapers toward bottom of rear door.
What I'm asking basically is if I can piece sport/ limited flares together?
Are they the same overall shape??
Thanks guys..
I believe the flares are also different where the flares wrap around the cladding at the base of the doors. Not sure but if you were to put limited flares on without the cladding, I'd assume there would be some gaps there.
I know for sure the rear mud flaps are the same. I bought some from a limited and sport edition and they have the same part number.
Ok, so I'm assuming they are pretty much the same shape and the only differences are the two sections that connect to door cladding for the limiteds.
So, in order for me to install the sport flares..
I would need: the front bumper flare, front wheel flare that tapers off (one piece), rear mud guard flare, flare over rear wheel, rear door flare without cladding attached.
Thanks guys
There is a difference in the flares though. I don't remember whether its the limited or the sport edition but I believe one of them is wider than the other. So for the piece that goes over the rear wheel I think you need to be sure that's from a sport edition and not a limited.
Damn! Looks like I'm only using the mudflaps from this limited set!
Any inexpensive sources for the sport flares?
Thanks guys
Freddygino324
