Are PIAA H11 Extreme White Plus Bulbs Better than Stock?
From what I see an H9 is a single filiment bulb. They have one 65 watt filliment so it would be brighter than the 55 watt H11 low beam. You would lose your high beam.
why would u lose ur high beam? the 5th gen light uses a 60W HB3/9005 for the high beam. & H11 for the lows & fogs. u could also use a HIR bulb (9011) to replace the 9005, it would be much brighter. ur quote states- """ It also was suggested that I try an H9 bulb. While H9's are 65watts as opposed to the H11 55watts the H9's only have a single filament so you would lose your high beam. For single filament applications such as fog lights or a setup with separate high and low beams this would work."""
