Are the TRD OR's factory lifted a bit? AKA is my truck lifted?
Quiero
I bought a new to me TRD ORP which came as a CPO '18 with brand new 32" KO2's. Zero rubbing.
Is it just me or is it also lifted a bit? Compared to a plain jane SR5 it is, but I wondered if it was factory. It has Toyota marked shocks, black springs that look stock.
glVdxu5
Edit: pics are not showing up =\. Does this place not like Imgur?
glVdxu5
unless something changed recently no - only the TRD pros come with a lift (small factory front IIRC)
glVdxu5
I’ve ran 32” KO2 on a TRD ORP 18’ for quite some time. Upon installation, the truck immediately looked taller than when it had the stock duellers. As far as I know, shocks/ springs are the same as the sr5.
The TRD pros are allegedly an inch taller up front but visually I can’t tell against my buddies’ 2020 pro when he was on his stock tires.
It's the exact same suspension as the "plain jane SR5".
32s as in 265/70r17 (the stock size)???
You forgot the ".jpg" in the image link... Hope this helps! :)
Rig looks sweet btw! 32" 265/70/17 is stock.
Since the 4Runners from the factory are "raked" (nose down) by about two inches, most people "level" them by raising the front more than the rear.
You can check the level by measuring the distance from the center of the wheel to the bottom of the fender edge above the wheel. If your 4Runner is level, those distances will be the same.
I installed the Rough Country leveling kit on my SR5 which raises the front 2-3 inches and rear only one inch.
It is hard to tell from your picture, but it looks like your 4Runner is still raked.
the KO2s are slightly larger than the factory tires, but it's mostly just cause it looks more aggressive
