Arguably my best purchase yet
If that's the best yet, you've got a lot of room for more "bests". My best has been all of the suspension bushings, absolutely transformed the quality of ride.
I got a mini--antenna cable adapter, and a 'Y' junction, and hooked the rear window antenna up to my aftermarket headunit. Previously, that was disconnected and only the normal sized fender power antenna was hooked up. And then installed a switch to turn 'off' the front power antenna. And what I've found is that the rear window antenna works so well, that by the time I start losing reception on a station, flipping the switch and raising the power antenna barely makes any improvement. I don't think I've bothered raising it for a couple of years now.
Not what I used but it probably works better: Amazon.com: Carxtc Diversity Antenna Harness Adapter When Installing a New Radio, Fits Toyota 4Runner that has two antenna connector plugs : Electronics
I'm going this way myself. I want to put my GMRS antenna on the OEM Hole. I barely use the radio anyway, and my Handheld GMRS radios actually have a RADIO station function anyway.
Criminally expensive ($70), but the 30 second install, no mods needed and IMO better reception. It's already paid for itself. I added a dab of Loctite in case someone trys to steal it as they are easily unscrewed.
Agree on the criminally expensive but it does look clean.
Its a great mod but am I the only one that likes the stock antenna. I am on my 3rd antenna and second motor but still like the stock operation.
Nope. You are not.. :)
Me, too. I still have the original power antenna. I've added a dash switch to cut the power during normal operation. I've found that the 'diversity antenna' in the passenger rear window does fine under most circumstances. When I do need the mast antenna for reception, I'm pretty fringe-y for that station. Then it's time for the aux input or bluetooth.
I'm on the opposite end of the spectrum from you lol I plan on removing the entire antenna assembly completely even though mine is still in great condition and operational. I never listen to the radio.
Me, too. I still have the original power antenna. I've added a dash switch to cut the power during normal operation. I've found that the 'diversity antenna' in the passenger rear window does fine under most circumstances. When I do need the mast antenna for reception, I'm pretty fringe-y for that station. Then it's time for the aux input or Bluetooth.
I like the switch to idea.. I just turn my radio off but I can see if i put an aftermarket radio in. I can run that power antenna to a toggle. ;-) As I don't use the radio much at all just the speakers for my Bluetooth connection. :-)
I liked the stock antenna, being that you're on your third though lol.
I really had no choice, my power antenna wont' go/wouldn't go down on its own unless the vehicle was turned off with the aftermarket head unit.
Like I always say. It's your rig your choices. There is nothing wrong with changing your antenna if you want to..:) Lots of people do.. :D
Sent from my SM-A505U using Tapatalk
Not a fan of Amazon so I went directly to the source, “Theantennasource.com” to be exact.
Avoided using Amazon and saved a few $$ as well.
Free shipping and lower sale price.
Ordered on 7/15, in my mailbox on 7/18.
Install under one minute, great reception.
Zero complaints.
Zero complaints.
Oh hell yeah Sarki!
Zero complaints.
Sarki, did you do anything with the power motor as it is? Mine still works, you can hear it trying to go up and down.
DJNutshell
