kball
If you want to upgrade/change your armrest and you have any common sense, do it the way bgmac did. Just follow the link
http://www.toyota-4runner.org/3rd-gen-t4rs/54787-armrest-mod.html
If you like to be different and jack stuff up, read on!
I found this website that sells strap on armrest boosters. Auto Chic Armrests
They sell 2.5 and 3.5 inch thick armrests. Vinyl is $60 Leather is $100 (you remember I mentioned the common sense part earlier....)
I bought a 2.5 inch model in the color they call parchment
I had to be able to use the original mounting hardware so it would fit on the center console. The original piece had a bulging top so I dremeled and hack sawed till it was pretty flat.
Then I needed a base that was flat and hard. It needed to fit into the vinyl cover so it had to be thin. Plus I had to be able to drill into it so I thought... wood or... this, a cutting board.
As you can see I trimmed the cutting board down to the right size to fit into the cover and then drilled out the holes to match the original mounting hardware.
then I shoved the cutting board into the new armrest and attached the mounting bracket.
Then I trimmed off the straps and mounted it in the truck. The color is a little light but it's close enough for me and it feels great!!
whew, time for a Guinness!
