At least I have first gear.
Dirtyfingers
Senior Member
Okay so I redid my valve covers the other day and I was going by the book on this one. I had a master mechanic over my shoulder making sure I didn't eff it up. When I buttoned everything up and started it up immediately the oil light came on. Whe I was driving it back the check engine light came on as well which I will get that code later today. Anywho, I have first gear which is all powerful and whatnot, but once it shifts into second ALL power is gone, I mean everything it goes from 200hp to 2. When I put the pedal to the metal all I get is no rpm over 2300, I've adjusted cables checked connections, rechecked connections and so on. I feel like resetting the computer might have thrown something out of whack. There is a slight hunting when I have the pedal mashed, so it makes me think the throttle cable is bugged up. What should I do?
You had to have hooked something back up wrong. Do you know anyone with a similar year 4runner you can compare vacuum connections to and stuff?
I'm pretty sure I did it right, but I will be the first to admit when I'm wrong something had to of been wrong. I don't want to drive it more then a mile because if the oil light and it's still leaking from somewhere.
